| » Gas Dryer short cycles |
Model Number: 11087181110 Brand: Kenmore Age: More than 10 years
The dryer works fine for 15 seconds then the burner goes out. After about 1 minute it relights and burns for 15 seconds then burner goes out. I tryed trouble shooting by bypassing the high temp thermostat. After doing this, the burner remained lit. Thinking this was the problem I replaced the high temp thermostat. (Since I was doing this I also replaced the low temp thermostat) After replacement I ran the dryer only to see that it ran as it did before for 15 second cycles. I again bypassed the high temp thermostat and the dryer again worked fine. I reconnected the new thermostat, it again went back to 15 second cycles. Any suggestions?
| Display Modes | |
| Dryer takes two cycles to dry | SlowGin | Dryer Repair | 3 | 11-09-2007 02:14 AM |
| short in wire | dwstevens | Dryer Repair | 1 | 10-29-2007 04:11 PM |
| Maytag dryer not heating up on all cycles and not properly drying clothes. | radioman464 | Dryer Repair | 1 | 10-18-2007 04:48 AM |
| dryer quits running after a short time | magictickler | Dryer Repair | 1 | 10-01-2007 03:48 AM |
| Gas Dryer not drying during run cycles | GMP | Dryer Repair | 1 | 09-28-2007 08:42 AM |
