the tumbler makes alot of noise. when i look into the dryer i can see the support wheels for the tumbler. if i replace the support wheels for the tumbler will that solve my problem:o
Here are your parts Replacement parts for KENMORE 11086568110 | AppliancePartsPros.comAll I can say is probably especially if the noise is a thumping like a pair of sneakers in the drum. Since you have to open it up you might as well give it a bit of an overhaul so also check the belt, the idler wheel, the front supports, drum seals, etc. Also give the interior a good cleaning including the blower wheel. Might as well clean and check you vent system while you are at it. |
THIS FORUM IS DEAD!!!!!!! |
