jayboy
#1 Posted : Saturday, November 3, 2007 6:54:58 PM(UTC)
jayboy
My gas dryer runs, but the it won't ignite. I replaced the igniter and it still does not glow, so it must not be getting power. There is continuity for the flame sensor, both solenoids, and both thermostats. I do here some intermittent clicking/static like noise from the solenoids, but I don't think a bad solenoid would prevent the igniter from glowing. I have not checked the thermal fuse because I don't know where it is. The sears part diagrams are not helping me.
#2 Posted : Sunday, November 4, 2007 1:35:23 AM(UTC)
Post back when you get a meter.
jayboy
#3 Posted : Sunday, November 4, 2007 6:56:14 AM(UTC)
jayboy
I have a multimeter, that is how I checked the continuity for everything but the thermal fuse. Anyway, the thermal fuse is located on the blower housing, which is easily accessed by removing the back panel of the dryer. The thermal fuse is located in the back near the bottom center.
bldyfinger
#4 Posted : Sunday, July 6, 2008 5:35:19 PM(UTC)
bldyfinger
Was it easy to replace?
jayboy
#5 Posted : Tuesday, July 8, 2008 4:47:31 PM(UTC)
jayboy
The thermal fuse is easy to replace. The hardest part is taking off the back panel. Once you get the panel off you will have an easy time replacing the thermal fuse.
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
