Discuss
Dryer heats up, makes quiet humm but won't run
 in
Dryer Repair
When I try to start my dryer, it heats up, smells like it's burning (like a space heater smells when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats up, makes quiet humm but won't run
  #1 (permalink)
Old 05-04-2011, 05:08 PM
Junior Member
osuchamp1 is on a distinguished road
Default Dryer heats up, makes quiet humm but won't run
Model Number: MDE7657AYW   Brand: Maytag   Age: 5 - 10 years
When I try to start my dryer, it heats up, smells like it's burning (like a space heater smells when it's on), and makes a quiet noise (also like the noise a space heater makes). The motor will not run, nor will the drum turn. I haven't tried to manually turn the drum yet, but will.
My question is, this dryer is about 10 yrs old. Do you think it would be worth it to fix, or should I just buy a new dryer? Any idea on ballpark cost to fix if it's a bad motor (parts, labor, etc.)?
Thanks so much for your help!
Ads By Google
Related Models
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
Maytag MDE9606AUW Dryer - Ele
Maytag MDE9606AYA Dryer - Ele
Maytag MDE9606AYQ Dryer - Ele
Maytag MDE9606AYW Dryer - Ele
Maytag MDE9606AZA Dryer - Ele
Maytag MDE9606AZQ Dryer - Ele
Maytag MDE9606AZW Dryer - Ele
Maytag MDE9700AYM Dryer - Ele
Maytag MDE9700AYQ Dryer - Ele
Maytag MDE9700AYW Dryer - Ele
Maytag MDE9700AZM Dryer - Ele
Maytag MDE9700AZW Dryer - Ele
Maytag MDE9706AYA Dryer - Ele
Maytag MDE9706AYW Dryer - Ele
Maytag MDE9706AZW Dryer - Ele
Maytag MDE9766AYW Dryer - Ele
Maytag MDE9766AZW Dryer - Ele
Maytag MDE9800AYQ Dryer - Ele
Maytag MDE9800AYW Dryer - Ele
Maytag MDE9800AZQ Dryer - Ele
Maytag MDE9800AZW Dryer - Ele
Maytag MDE9806AYA Dryer - Ele
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
  #2 (permalink)
Old 05-05-2011, 03:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE7657AYW DRYER- ELE | AppliancePartsPros.com
It will give you an idea on parts costs.
Cannot give an estimate on the labor cost.
Once you narrow it down get an estimate from a local repair shop.
Also I cannot say if it is worth fixing. Depends on what needs replacing, if you can do it yourself, what king of shape the dryer is in and if it needs additional parts (rollers, glides etc.) to give it a basic overhaul.
Are you sure the motor is not turning?
Perhaps you have just blown a belt and the hum you hear is the motor running.
If you have air flow then the motor is running.
The reason it could be the above is that the motor has 2 centrifugal switches on it. They close when the motor gets close to operating speed. One of them switches in the heater so that you do not have heat without the air flow.
So if you have heat and air flow it is probably the belt.
If you have heat and no air flow it is a problem with the centrifugal switch mechanism. Could be it is clogged solid with lint or may be broken and is stuck in the motor running position.
The reason for this is that the second switch disconnects the start winding.
So if the switches are being activated when the motor is at rest then the motor is trying to start but the start winding is not in circuit.
Here is a service manual which should be close to your unit in case you want to tackle this yourself.
http://appliancedigest.com/index.php...service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
__________________
  #3 (permalink)
Old 05-05-2011, 05:33 PM
Junior Member
Default
Thank you so much for your help! Have a great week!
  #4 (permalink)
Old 05-11-2011, 07:50 AM
Junior Member
Default
Thanks so much for the help! You were right. It was the motor. My husband know a former Maytag service technician who said if we replace the motor (with centrifugal switch), the belt and the idler arm spring, we could easily get another 10 years out of our Maytag.
You saved me the cost of a new dryer (and washer, since they have to match of course!)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Llights come and humm on but wont run. Help please 1hughie1 Dishwasher Repair 11 02-23-2011 12:45 PM
Dryer heats, but won't start up, makes "ugggggh" noise.. chauncy Dryer Repair 1 11-21-2010 10:25 PM
Dryer heats, drum turns, but makes loud noise dj1988 Dryer Repair 3 11-04-2010 03:56 PM
whirlpool oven sometimes heats/sometimes doesn't/makes awful sound when ignites crazyoven Oven Repair (including Ranges and Cooktops) 3 07-02-2009 04:06 PM
dryer makes squeeking noise at first start up and while running as it heats it stops mommachicken63 Dryer Repair 3 11-20-2008 08:49 AM
