| » Won't turn off |
Model Number: Teds740pq0 Brand: Estate Age: 1 - 5 years
The dryer is currently not working. While it was in use it started to run forever without cutting off. It would heat but I just had to stop it manually when clothes were dry. One day it quit heating. So I took it apart and it needs a new heating element but I'm also wanting to fix the problem with it not cutting off on it's on. I really don't have any tools to test voltage or anything. Just screwdriver and sockets. So any advice is appreciated
Replacement parts for WHIRLPOOL TEDS740PQ0 29"ELECTRIC DRYER | AppliancePartsPros.com See the attachment for the wiring diagram. If when it was not turning off you did not check it in timed dry then there is a possibility that replacing the heating element will also fix the unit not shutting off. In auto modes the timer motor gets power through the heating coil when the coil is shut off. So depending how the coil failed it could have been stopping the timer from advancing.
__________________
| Display Modes | |
| Refer will not turn off - motor runs until I turn down thermostat | Ahhnother8 | Refrigerator & Freezer Repair | 3 | 06-17-2010 04:51 PM |
| Fan won't turn on | GTom | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 10-05-2009 08:43 PM |
| turn table doesnt turn | adam belentrobled | Microwave Repair | 1 | 09-12-2009 09:33 AM |
| Stove would not turn off had to turn off breaker | Jim Cllen | Oven Repair (including Ranges and Cooktops) | 1 | 02-18-2009 05:42 PM |
| micro wave light won't turn off micro wave does not turn on. | Tim Bennett | Microwave Repair | 1 | 08-27-2008 02:25 PM |
