my dryer wont heat ... HELP !!!!1
dryer wont heat had the element tested and the thermostat tested they are fine what should i do next ??? thanks ..
Check BOTH CIRCUT BREAKERS for the dryer, Yeah,I know it will run, But check the BREAKERS!!!!:)
Also check the thermal fuse, that is mounted on the element housing up top. Take the wires off, before you ohm it out. Don't forget to unplug the dryer when you do. Tom ********************************************
| All times are GMT -7. The time now is 12:15 AM. |
