AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
LG Dryer stops heating, requires manual thermostat reset
LG LP GAS dryer works for a weekend, then next weekend when I start it, it doesn't heat up. I can reach in the side and push a thermostat reset button, it it works fine until the next weekend.
Starting yesterday, it doesn't heat at all, even when I press the reset button on the thermostat.
Yesterday, I ordered the thermostat that can be reset (Part# M230). There are two other thermostat-type devices on this machine's schematic. One is a 'hi-limit' thermostat (Part# M220), and the other is called Sensor Assembly (Part# M240). Should I replace these second two parts as well?
Any parts that could be failing that causes this?
Dryer Repair
