| » 3 prong to 4 prong maytag dryer! Please help |
A model number would help as some units are hooked up different so you should look at the installation sheet.
On older units the norm is: 3 Wire: Ground and Neutral are the same so there is a wire (ground strap) from the white connection point (usually the center connector) to the machines frame. 4 Wire: Ground and Neutral are separate so the ground strap is removed/disconnected. The white from the line cord then goes to the Neutral on the terminal strip. The green or bare wire from the line cord is then connected to the units frame where the ground strap was connected. Include a model number and we should be able to find your install sheet.
__________________
| Display Modes | |
| 3 prong to a 4 prong ground wire issue | gyoryab | Dryer Repair | 1 | 02-06-2011 01:51 PM |
| Dryer Conversion: 3 prong to 4 prong, but a little weird. | jambles | Dryer Repair | 2 | 07-04-2010 12:16 AM |
| installing a new 4 prong cord to 3 prong dryer | nmcfay1226 | Dryer Repair | 9 | 02-09-2010 03:23 PM |
| Help changing a 3 prong to a 4 prong (dryer) plug | Micheline | Dryer Repair | 4 | 11-28-2009 08:27 PM |
| 3 prong to 4 prong dryer conversion | chestarse | Dryer Repair | 9 | 11-17-2009 05:04 AM |
