Here are your parts includes a wiring layout.
Replacement parts for MAYTAG MDE6200AYW DRYER- ELE | AppliancePartsPros.comHere is a service manual, it has an actual wiring diagram, see page 10-25.
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.comYou have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
First I would check/clean the vent system.
Next check for a grounded element especially if the unit also heats on air only.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run and the thermostats cannot regulate it.
Next check the cycling thermostat. You will notice that the thermostat has a heater built into it. On delicate this heater is turned on, it adds heat to the thermostat so that it cycles more often reducing the heat output of the dryer.
It should be around 25,000 ohms. This is a bit of a guess on my part but all that matters is that does it have continuity.
On delicate this internal heater is full on.
On medium the 10K resistor is in this circuit so the heater is partially on, so you get more heat.
On high the heater is off.
Next to check would be the temperature selector switch.
