Discuss
heat sensor fuse
 in
Dryer Repair
have never had this problem before. Blows fuse during dryer cycle (fuse pt # 40113801) baught new fuse locally and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » heat sensor fuse
  #1 (permalink)
Old 04-30-2011, 06:20 PM
Junior Member
bobm127 is on a distinguished road
Default heat sensor fuse
Model Number: ALE443RAW   Brand: Amana   Age: More than 10 years
baught new fuse locally and installed it.(cost$19.88, your cost $4.70)
Dried 2 loads and started 3rd when same thing happened again.
No need to replace it again until I find out why, Where should I start?Bob
Ads By Google
Related Models
Amana ALE443RAW Dryer - Ele
Amana ALE443RCW Dryer - Ele
Amana ALE565SAC Dryer - Ele
Amana ALE565SAW Dryer - Ele
Amana ALE643RAC Dryer - Ele
Amana ALE643RAW Dryer - Ele
Amana ALE643RBC Dryer - Ele
Amana ALE643RBW Dryer - Ele
Amana ALE643RCW Dryer - Ele
Amana ALE665SAC Dryer - Ele
Amana ALE665SAW Dryer - Ele
Amana ALE866SAC Dryer - Ele
Amana ALE866SAW Dryer - Ele
Amana ALE866SBC Dryer - Ele
Amana ALE866SBW Dryer - Ele
Amana ALE866SCW Dryer - Ele
Amana ALE868QAW Dryer - Ele
Amana ALE868QCW Washer - Top Loading
Amana ALE956EAC Dryer - Ele
Amana ALE956EAW Dryer - Ele
Whirlpool ALF12420
Whirlpool ALF15040
Whirlpool ALF20040
Whirlpool ALF21040
Whirlpool ALF24040
Whirlpool ALFE0940
Whirlpool ALFH0820
Whirlpool ALFW0940
Amana ALG120RAW Dryer - Gas
Amana ALG230RAW Dryer - Gas
Amana ALG230RCW Dryer - Gas
Amana ALG331RAC Dryer - Gas
Amana ALG331RAW Dryer - Gas
Amana ALG331RMC Dryer - Gas
Amana ALG331RMW Dryer - Gas
Amana ALG443RAC Dryer - Gas
Amana ALG443RAW Dryer - Gas
Amana ALG443RCW Dryer - Gas
Amana ALG565SAC Dryer - Gas
Amana ALG565SAW Dryer - Gas
Amana ALG643RAC Dryer - Gas
Amana ALG643RAW Dryer - Gas
Amana ALG643RBC Dryer - Gas
Amana ALG643RBW Dryer - Gas
Amana ALG643RMC Dryer - Gas
Amana ALG643RMC1 Washer - Top Loading
Amana ALG643RMW Washer - Top Loading
Amana ALG643RMW1 Washer - Top Loading
Amana ALG665SAC Dryer - Gas
Amana ALG665SAW Dryer - Gas
Amana ALG866SAC Dryer - Gas
Amana ALG866SAW Dryer - Gas
Amana ALG866SBC Dryer - Gas
Amana ALG866SBW Dryer - Gas
Amana ALG866SCW Dryer - Gas
Amana ALG868QAW Dryer - Gas
Amana ALG868QCW Washer - Top Loading
Amana ALG956EAC Dryer - Gas
Amana ALG956EAW Dryer - Gas
Whirlpool ALJ00520
Whirlpool ALJ07520
Whirlpool ALJ10020
Whirlpool ALJ12020
Whirlpool ALJ18040
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
International ALR1100AJQ Range - F/s Std Gas
International ALR1100AJW Range - F/s Std Gas
International ALR1420BDQ Range - F/s Std Gas
International ALR1420BDW Range - F/s Std Gas
Admiral ALR1450AJW Range - F/s Std Gas
International ALR1450BJW Range - F/s Std Gas
International ALR5715QDQ Range - S/c F/s Gas
International ALR5715QDS Range - S/c F/s Gas
International ALR5715QDW Range - S/c F/s Gas
Amana ALW110RAW Washer - Top Loading
Amana ALW210RAW Washer - Top Loading
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMW Washer - Top Loading
International ALW221RJW Washer - Top Loading
Amana ALW410DAW Washer - Top Loading
Amana ALW430RAC Washer - Top Loading
Amana ALW430RAW Washer - Top Loading
Amana ALW432RAW  Washer - Top Loading
Amana ALW450QAC Washer - Top Loading
Amana ALW450QAW Washer - Top Loading
Amana ALW480DAC Washer - Top Loading
Amana ALW480DAW Washer - Top Loading
Amana ALW540RAC Washer - Top Loading
Amana ALW540RAW Washer - Top Loading
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMW Washer - Top Loading
Amana ALW680RAC Washer - Top Loading
Amana ALW680RAW Washer - Top Loading
Amana ALW780QAC Washer - Top Loading
Amana ALW780QAW Washer - Top Loading
  #2 (permalink)
Old 05-01-2011, 03:50 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for ALE443RAW models | AppliancePartsPros.com
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Also check for any signs that the coil touched the case when hot and then disconnected itself when it cooled down.
The hi-limit should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
If the dryer seems to be running hot for the last while then it has probably been running on the hi-limit. So you have to find out why.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
  #3 (permalink)
Old 05-03-2011, 03:57 PM
Junior Member
Default thermal fuse
followed your instructions exactly.everything fell in range as you described it.
purchased another fuse and installed it as directed.
tried dryer long enough to see if it would heat and it did!
next tried a small load and started it on medium heat and it nevered dried them before the same problem again.
that leaves the changing cycling thermostat.I don't know where it is located, any help there?
bobm
  #4 (permalink)
Old 05-03-2011, 04:34 PM
Senior Expert
APP Volunteer
Default
Cycling thermostat is Item 12 in Section 6
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sensor Cycle Doent Heat mark6909 Dryer Repair 0 04-13-2011 12:10 PM
Still Getting an F3 Code after heat sensor was replaced Scott Carlson Oven Repair (including Ranges and Cooktops) 1 08-16-2010 09:49 AM
Thermal fuse and Flame sensor wiring cwizzards Dryer Repair 2 05-08-2010 08:37 AM
C7 Heat Sensor not working rothfolkj Dishwasher Repair 0 07-30-2009 06:11 AM
heat sensor bad? karaokemom@tds.net Oven Repair (including Ranges and Cooktops) 0 01-07-2008 06:44 PM
