Discuss
start button not turning on dryer
 in
Dryer Repair
My dryer was working fine and after I had dried a load of clothes and went to push the start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » start button not turning on dryer
  #1 (permalink)
Old 01-21-2009, 09:31 AM
togetheruandme togetheruandme is offline
Junior Member
togetheruandme is on a distinguished road
Default start button not turning on dryer
Brand: Roper   Age: 5 - 10 years
My dryer was working fine and after I had dried a load of clothes and went to push the start button, the dryer would not start. I wondered if it could be the start button switch.
  #2 (permalink)
Old 01-21-2009, 05:14 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
the first thing you want to do is turn the dryer breaker off, and on a few times. You did not give your model #, so I will assume, that if you can take the back panel off the dryer, close to the bottom, is a white part, that is an inch and a half long, and a half inch wide, and has 2 wires coming to it. That is the thermal fuse. That could be your problem, or the door switch. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 1 12-17-2009 10:39 AM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
Dryer Start button broke off when turning knob debandchazmo@aol.com Dryer Repair 1 01-27-2009 03:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
