| » Dryer not drying well. Takes 2 or 3 cycles to dry all the way |
Model Number: glet1031fso Brand: Frigidaire Age: 1 - 5 years
I have a stack washer dryer combo. It used to dry clothes in 30 to 50 min and now it takes 2 or 3 cycles of 70 min to dry a load. Could it be the Heating Element going bad or to they just go out? Please help.
Replacement parts for FRIGIDAIRE GLET1031FS0 Frigidaire/laundry Center | AppliancePartsPros.com Here is a wiring diagram http://manuals.frigidaire.com/prodin.../134806300.pdf It could be the heating coil or something else but the most common cause is a dirty or malfunctioning vent system. Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly. If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock. Both the above will let you check the temperature and the air flow. Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
__________________
| Display Modes | |
| Ele. Dryer takes more than 2-3 cycles to dry | highstakes | Dryer Repair | 1 | 02-20-2011 07:59 AM |
| Dryer takes 2-3 cycles to dry. | nazriah3 | Dryer Repair | 0 | 10-28-2010 10:56 AM |
| dryer takes 2 or 3 cycles to dry | Photoplay1 | Dryer Repair | 2 | 06-08-2009 05:07 AM |
| My dryer takes 3-4 cycles to dry | IDEZ | Dryer Repair | 1 | 05-22-2009 03:30 PM |
| Dryer takes two cycles to dry | SlowGin | Dryer Repair | 3 | 11-09-2007 01:14 AM |
