| » Dryer not drying |
Model Number: dx4500ga1ww Brand: GE Age: 1 - 5 years
My dryer just stooped heating up enough to dry clothes. The start button stopped working and so I just have to turn the dial for any cycle and it goes on but the cycles run continuously without completely drying. Silver heat shield inside gets hot but I don't feel air blowing. It spins just fine. This is just over 18 months old any suggestions?
Ads By Google Related Models Last edited by sue1759 : 11-02-2007 at 09:28 AM. Reason: adding more information |
Hi sue1759
The first thing I would do is check the continuity across the start switch terminals. It should be normally open and if it's closed then replace the start switch. How did you check the air flow? Did you dis connect the vent hose from the dryer? - The pat number for the new start switch AP2042901 - Here are the break down diagrams for the GE dryer Model DX4500GA1WW Good luck. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I really need you to answer on my questions in order to help you.
__________________
If the dryer can be turned on with just the timer and without the start switch, then the start switch is probably bad and has to be replaced.
If the dryer is working with the door open this is a major safety issue and the door switch has to be replaced or the door needs an adjustment. If the dryer heats up but not drying properly, most likely the problem is a clogged vent or the blower inside the dryer. Disconnect the vent hose from the back of the dryer and run a load with the hose being disconnected. If you see a difference, then the vent has to cleaned. Gene.
__________________
| Display Modes | |
| Gas dryer not drying | bkcprice1 | Dryer Repair | 3 | 02-26-2009 02:16 PM |
| Dryer not drying | cpitt2@yahoo.com | Dryer Repair | 1 | 12-24-2008 04:49 AM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
| gas dryer not drying | losanft | Dryer Repair | 0 | 02-03-2008 08:43 AM |
| dryer not drying enough | lt3 | Dryer Repair | 5 | 01-04-2008 10:38 AM |
