popow1
#1 Posted : Tuesday, January 20, 2009 12:28:16 PM(UTC)
popow1
we need to know how to get the front panel off thanks
kayakcrzy
#2 Posted : Wednesday, January 21, 2009 8:13:43 AM(UTC)
kayakcrzy
Slide a putty knife under the top of the dryer, about 3 inches from the end, and you will hit a clip, that will release the top on that side. Then do the same on the other side. Once the top is up, rest it on the back wall. Now to remove the front, look inside the front about 4 inches down from the top on the left side is a 5/16s screw. Remove it, and the one on the other side. Then grab the front on the left side, and pull up quick and hard, and that will release it from the bottom, and do the same on the other side, and then release the wiring harness on the door swich, and you have it. Tom ApplianceEducator.com
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
Maytag Gas Dryer loses heat (Dryer Repair)
by editbot 2/25/2014 10:42:53 AM(UTC)
