Discuss
What diagnostic procedure for my autodry problem?
 in
Dryer Repair
I have had this drier since I bought my home 2yrs ago and the behavior has always been the same,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » What diagnostic procedure for my autodry problem?
  #1 (permalink)
Old 04-28-2011, 09:02 PM
Junior Member
ls3c6 is on a distinguished road
Default What diagnostic procedure for my autodry problem?
Model Number: MDG6200AWW   Brand: Maytag   Age: 5 - 10 years
I have had this drier since I bought my home 2yrs ago and the behavior has always been the same, i've removed the front cover and exhaust/squirrel cage assembly when I first was disappointed with it's performance and everything is clean.
When I use the auto-dry setting I must put the selector on "less dry" and even then it seems to run more by time than "sensing" the temperature... usually in this mode loads take 60-65 mins before I get the alert it's gone to cool down mode.
This isn't like most auto-dry "dial never moves" concerns, it does eventually finish the cycle... but if I were to select "more dry" it would be much much longer.
It does heat and the clothes come out dry, but I think it may be running for too long.
I just ran the dryer with the front cover off in autodry mode and noticed that immediately the igniter glowed bright orange, gas was emitted and it had a flame for about 15 seconds... but then it clicked off, like it was told to.. but maybe not supposed to?
Based on my limited knowledge of how it's supposed to function, does this sound like a problem with the multi-thermostat 5 pin there in the exhaust path? Any steps to test it with a multimeter?
How often should the flame cycle on/off during the auto-dry? Before I removed the cover I always assumed the flame was always on during drying, guess not.
Ads By Google
Related Models
Maytag MDG6200AWW Dryer - Gas
Maytag MDG6400AWQ Dryer - Gas
Maytag MDG6400AWW Dryer - Gas
Maytag MDG6460AWW Dryer - Gas
Maytag MDG6657BWQ Dryer - Gas
Maytag MDG6657BWW Dryer - Gas
Maytag MDG6700AWM Dryer - Gas
Maytag MDG6700AWW Dryer - Gas
Maytag MDG6800AWB Dryer - Gas
Maytag MDG6800AWQ Dryer - Gas
Maytag MDG6800AWW Dryer - Gas
Maytag MDG7057AWQ Dryer - Gas
Maytag MDG7057AWW Dryer - Gas
Maytag MDG7057BWQ Dryer - Gas
Maytag MDG7057BWW Dryer - Gas
Maytag MDG7400AWQ Dryer - Gas
Maytag MDG7400AWW Dryer - Gas
Maytag MDG7460AWQ Dryer - Gas
Maytag MDG7460AWW Dryer - Gas
Maytag MDG7500AWQ Dryer - Gas
Maytag MDG7500AWW Dryer - Gas
Maytag MDG75MNAWW Dryer - Gas
Maytag MDG75MNVWQ Dryer - Gas
Maytag MDG75MNVWW Dryer - Gas
Maytag MDG75PN1AW Dryer - Gas
Maytag MDG75PN2VW Dryer - Gas
Maytag MDG75PNAVW Dryer - Gas
Maytag MDG75PNHWQ Dryer - Gas
Maytag MDG75PNHWW Dryer - Gas
Maytag MDG75PNVVQ Dryer - Gas
Maytag MDG75PNVVW Dryer - Gas
Maytag MDG75PNVWQ Dryer - Gas
Maytag MDG75PNVWW Dryer - Gas
Maytag MDG7600AWQ Dryer - Gas
Maytag MDG7600AWW Dryer - Gas
Maytag MDG7657AWQ Dryer - Gas
Maytag MDG7657AWW Dryer - Gas
Maytag MDG7657BWQ Dryer - Gas
Maytag MDG7657BWW Dryer - Gas
Maytag MDG7658AWQ Dryer - Gas
Maytag MDG7658AWW Dryer - Gas
Maytag MDG7658BWQ Dryer - Gas
Maytag MDG7658BWW Dryer - Gas
Maytag MDG76PCBWS Dryer - Gas
Maytag MDG76PCBWW Dryer - Gas
Maytag MDG7757AWQ Dryer - Gas
Maytag MDG7757AWW Dryer - Gas
Maytag MDG7758AWQ Dryer - Gas
Maytag MDG7758AWW Dryer - Gas
Maytag MDG77PNAWW Dryer - Gas
Maytag MDG77PNSWW Dryer - Gas
Maytag MDG8000AWQ Dryer - Gas
Maytag MDG8000AWW Dryer - Gas
Maytag MDG8000BWQ Dryer - Gas
Maytag MDG8000BWW Dryer - Gas
Maytag MDG8057AWQ Dryer - Gas
Maytag MDG8057AWW Dryer - Gas
Maytag MDG8057BWQ Dryer - Gas
Maytag MDG8057BWW Dryer - Gas
Maytag MDG8058BWQ Dryer - Gas
Maytag MDG8058BWW Dryer - Gas
Maytag MDG8400AWQ Dryer - Gas
Maytag MDG8400AWW Dryer - Gas
Maytag MDG8416AWA Dryer - Gas
Maytag MDG8416AWW Dryer - Gas
International MDG8426AAW Dryer - Gas
International MDG8426AEW Dryer - Gas
International MDG8426AGW Dryer - Gas
Maytag MDG8500BWW Dryer - Gas
Maytag MDG8506AWA Dryer - Gas
Maytag MDG8506AWW Dryer - Gas
International MDG8550AGW Dryer - Gas
International MDG8550BGW Dryer - Gas
Maytag MDG8600AWQ Dryer - Gas
Maytag MDG8600AWW Dryer - Gas
Maytag MDG8757AWQ Dryer - Gas
Maytag MDG8757AWW Dryer - Gas
Maytag MDG9206AWA Dryer - Gas
Maytag MDG9206AWW Dryer - Gas
Maytag MDG9206AXW Dryer - Gas
Maytag MDG9206BWW Dryer - Gas
Maytag MDG9306AWA Dryer - Gas
Maytag MDG9306AWW Dryer - Gas
Maytag MDG9306AXA Dryer - Gas
Maytag MDG9306AXW Dryer - Gas
Maytag MDG9316AWA Dryer - Gas
Maytag MDG9316AWQ Dryer - Gas
Maytag MDG9316AWW Dryer - Gas
Maytag MDG9316AXW Dryer - Gas
Maytag MDG9316BWQ Dryer - Gas
Maytag MDG9316BWW Dryer - Gas
Maytag MDG9357AWA Dryer - Gas
Maytag MDG9357AWQ Dryer - Ele
Maytag MDG9357AWW Dryer - Gas
Maytag MDG9360BWW Dryer - Gas
Maytag MDG9390AWW Dryer - Gas
Maytag MDG9390AXW Dryer - Gas
Maytag MDG9390BWW Dryer - Gas
Maytag MDG9420BWW Dryer - Gas
Maytag MDG9520BWQ Dryer - Gas
Maytag MDG9520BWW Dryer - Gas
Maytag MDG9557AWA Dryer - Gas
Maytag MDG9557AWQ Dryer - Gas
Maytag MDG9557AWW Dryer - Gas
Maytag MDG9557AXQ Dryer - Gas
Maytag MDG9557AXW Dryer - Gas
Maytag MDG9557BWQ Dryer - Gas
Maytag MDG9557BWW Dryer - Gas
Maytag MDG9606AWA Dryer - Gas
Maytag MDG9606AWQ Dryer - Gas
Maytag MDG9606AWW Dryer - Gas
Maytag MDG9606AXW Dryer - Gas
Maytag MDG9606BWQ Dryer - Gas
Maytag MDG9606BWW Dryer - Gas
Maytag MDG9700AWM Dryer - Gas
Maytag MDG9700AWW Dryer - Gas
Maytag MDG9706AWA Dryer - Gas
Maytag MDG9706AWW Dryer - Gas
Maytag MDG9766AWW Dryer - Gas
Maytag MDG9766AXW Dryer - Gas
  #2 (permalink)
Old 04-28-2011, 09:46 PM
Junior Member
Default
Update, the first time I tested and saw the flame go off quickly I wasn't holding the door against the frame, just the button.
Just now I checked the coils, got 574 ohms between 1-3 and 1320 ohms on the 2 prong unit.
While holding the door against the frame and running it in auto-dry, I checked the temperature output from the vent. At 155f the flame turns off, I hear what sounds like a click at the top near the timer, the temperature drops to 130 and I hear another click down below, again at 115 which I believe is the igniter coming on, then once it reaches 110 the flame is on and it gets back up to 155 before the flame turns off again... yet the timer does not advance and this cycle continued for 20 minutes without any movement in the timer.
In timed dry the timer works normally.
Seems the multi-temp sensor isn't working then or what?!
  #3 (permalink)
Old 04-29-2011, 12:43 PM
Junior Member
Default
bump for help.
  #4 (permalink)
Old 04-29-2011, 09:05 PM
Junior Member
Default
Update 2:
Dried a small load on auto-dry, monitoring exhaust temps during the entire cycle. It took 62 minutes to signal it was done, here is what it did:
1. Heats to 150f
2. Flame turns off, timer starts
3. Temp drops, at 130f timer stops.
4. Temp drops to 125f and begins going up again, timer still off.
5. Gets back to 150f, timer turns back on and runs until 130 is reached.
Looking at the service manual there should be a 15f window for cycling, not 25f... does this mean the cycling thermostat like I suspected? Anything else to check?
  #5 (permalink)
Old 05-02-2011, 06:30 AM
Junior Member
Default
OK ordered new coils and cycling thermostat, but noticed existing stat is a 150f with a -25f cycling rate, so is the above behavior i'm experiecing normal?!
  #6 (permalink)
Old 05-03-2011, 10:48 PM
Junior Member
Default
Cycling tstat and coils replaced, still experiencing 155-115-155-115f cycling and 75 minutes on autodry to dry a normal load with a few sweaters/pairs of jeans/shirts.
all these views and no input... no exhaust restriction, strong flame and no detectable problems... I guess the unit is just a design problem and I need to buy new.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Washer Pump Replacement Procedure dz63 Washer Repair 16 04-13-2013 04:54 PM
Reset Procedure for Whirpool Dishwasher dwclli Dishwasher Repair 2 02-07-2012 03:59 PM
Timer does not advance in autodry dugwms Dryer Repair 0 01-10-2011 06:15 PM
replace control panel procedure s moore Dryer Repair 0 01-04-2011 11:09 AM
Replace rollers and belt Procedure santafecider Dryer Repair 0 11-03-2008 07:32 AM
