Discuss
GE Front Drum Bearing
 in
Dryer Repair
My dryer has been making a horrible squealing noise. Last night we tore it apart and found that the front
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Front Drum Bearing
  #1 (permalink)
Old 11-02-2007, 08:13 AM
cassie31899 cassie31899 is offline
Junior Member
cassie31899 is on a distinguished road
Question GE Front Drum Bearing
Model Number: DPSR473EW0WW   Brand: GE   Age: 5 - 10 years
My dryer has been making a horrible squealing noise. Last night we tore it apart and found that the front drum bearing is wore right down to about nothing. I am just wondering what exactly I need to order to replace it. I am thinking: Front drum bearing and 4 slides, is that all???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-02-2007, 11:58 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi cassie31899
Yes, you are right. You have to replace the front drum bearing and four slides.
- The part number for the front drum bearing AP3790641
- The part number for the slide AP631382.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-02-2007, 12:10 PM
Junior Member
Default
Thank you so much for your help!!!
  #4 (permalink)
Old 11-02-2007, 12:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Please, keep me updated.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
problem with loose drum inside front loader Big G Washer Repair 1 12-18-2007 04:04 PM
kenmore front load washer drum off balance and bangs in one location kemily Washer Repair 2 12-18-2007 04:02 PM
How to Replace Bad Bearing/Leaky tub Geor2c Washer Repair 2 09-21-2007 04:02 AM
how do I: remove rear drum bearing frigid front load? treefrog Washer Repair 0 08-19-2007 02:12 PM
Rear Tub Bearing Justncase Washer Repair 5 08-08-2007 10:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
