| » kenmore he 4 dryer wont start |
Model Number: 11085862400 Brand: Kenmore Age: 5 - 10 years
Control panel lights up but when I push start buttonit clicks but won't come on! Had trouble last year and had to replace main control panel. Didn't know of it was that again or something else?
Replacement parts for KENMORE 11085862400 by Kenmore Elite | AppliancePartsPros.com I think that this unit is actually a Whirlpool Duet or at least close. Here is a manual. L-69 Whirlpool Duet Gas & Electric Dryers Service Manual - ApplianceDigest.com See then attachment for the tech sheet. Run the diagnostics to see if anything pops up. Could be a broken belt or the belt switch. Could be the thermal fuse in the motor circuit. Could be that the thermal fuse on the blower wheel (Item 7 in Section 3) has blown. Unplug the unit and check the fuse with a meter should be 0 ohms. Jiggery Pokery method is. Unplug the unit. Remove both wires from the fuse, short them together and tape them up so they will not short to the frame. Plug the unit in and give it a try. If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires. Also clean/check your vent system and the blower as these are the most common causes of it blowing.
__________________
| Display Modes | |
| My kenmore dryer wont start | Mike Swanson | Dryer Repair | 1 | 03-11-2010 11:25 AM |
| Kenmore Electric Dryer Wont Start | rwshevy | Dryer Repair | 1 | 02-05-2010 06:25 PM |
| kenmore dryer wont start | MOUSENUP | Dryer Repair | 1 | 09-07-2009 07:47 AM |
| kenmore dryer wont start | sargento52 | Dryer Repair | 2 | 09-01-2009 05:39 AM |
| Kenmore Dryer wont start | rrhoward78 | Dryer Repair | 2 | 02-01-2009 12:05 PM |
