| » Dryer inside light |
Model Number: lde8606ace Brand: Maytag Age: 1 - 5 years
Bought this electric dryer used- Ran it a couple times to test it heats/tumbles fine.But after its runs I open door to look inside and light stays on 2-3 seconds and then goes out! Is this normal function or is light switch going bad????
Replacement parts for MAYTAG LDE8606ACE DRYER- ELE | AppliancePartsPros.com Yes I would say the the switch (Item 10 in Section 4) is starting to stick closed. Take a look at the switch's actuator to see if there is some gunk on it. You could try spraying some electronics cleaner onto the actuator and then quickly pressing/releasing the actuator to see if that will free it up. Unplug the unit when doing this. Then let it sit a while so the solvent vapors can evaporate and plug it in and give it a try.
__________________
| Display Modes | |
| Dryer stopped mid cycle, not light on inside | melissag | Dryer Repair | 1 | 11-01-2009 04:18 AM |
| Advantium inside light | edgineer | Microwave Repair | 3 | 07-11-2009 06:17 PM |
| Dryer won't start, inside light won't come on | StaceyLee | Dryer Repair | 5 | 06-15-2009 06:19 PM |
| dryer only "hums" when power button is pushed, light on inside drum | mastersaint | Dryer Repair | 3 | 01-08-2009 11:25 AM |
| Light inside tumbler | bobjay | Dryer Repair | 1 | 12-22-2008 04:33 PM |
