| » Dryer Reset After Power Outage |
Model Number: MDE5500AYW Brand: Maytag Age: 1 - 5 years
I have a Maytag Neptune front loading dryer. There was a power outage last night and the power to the dryer did not restore. Is there a reset button for this dryer. i can not locate my manual.
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com There is no reset button. Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!!
__________________
| Display Modes | |
| No Power to Frig after Power Outage | kenneth.bernier@gmail.com | Refrigerator & Freezer Repair | 2 | 11-08-2010 12:38 PM |
| Whirlpool Range - Cannot reset time display after power outage | tgerstacker | Oven Repair (including Ranges and Cooktops) | 0 | 09-29-2008 09:45 AM |
| After power outage | Miqui | Oven Repair (including Ranges and Cooktops) | 2 | 06-01-2008 08:32 AM |
| Power Outage | ttorres21 | Microwave Repair | 3 | 03-25-2008 04:14 PM |
| Power Outage-Now My Dryer Is dead | Annie | Dryer Repair | 0 | 08-14-2007 08:49 AM |
