Discuss
Dryer Won't Start
 in
Dryer Repair
Try the following If that checks OK then with the unit unplugged tape one meter lead to Neutral at the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Won't Start
  #11 (permalink)
Old 07-20-2011, 02:36 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Try the following
If that checks OK then with the unit unplugged tape one meter lead to Neutral at the plug/line cord and leave it there.
Then work your way back through the units components till you find the open circuit.
__________________
  #12 (permalink)
Old 07-21-2011, 02:32 PM
Junior Member
danintennessee is on a distinguished road
Default
Quote:
Originally Posted by denman View Post
Try the following
Should I get continuity from Neutral to the timer? I get nothing there, at any of the contacts.
  #13 (permalink)
Old 07-22-2011, 02:43 AM
Senior Expert
APP Volunteer
Default
Yes, you should see a couple ohms (motor windings) at BU on the timer when the start switch is pushed and the door is closed.
__________________
  #14 (permalink)
Old 07-22-2011, 04:18 AM
Junior Member
Default
Well, I guess I've found the culprit then. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
