Discuss
clothes dryer wont heat timer wont work
 in
Dryer Repair
I have a Ge clothes dryer that was working fine then one day the timer stopped working. The dryer runs
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » clothes dryer wont heat timer wont work
  #1 (permalink)
Old 01-17-2009, 09:10 AM
Junior Member
tampee is on a distinguished road
Default clothes dryer wont heat timer wont work
Brand: GE   Age: 5 - 10 years
I have a Ge clothes dryer that was working fine then one day the timer stopped working. The dryer runs it just wont automatically shut off and it will not heat properly. It has to run two or three times longer than it normally would to dry a load of clothes. Once the load has dried the clothes feel hot and the dryer inside is hot but load another load of clothes and it still takes twice as long as it should to dry them. Any suggestions? I dont know if the timer has anything to do with it or if that is just a coincidence. Thanks for any suggestions. Its really been a good dryer so if its something I could fix I would like to.
  #2 (permalink)
Old 01-17-2009, 09:20 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check the air flow from the dryer to see if you have an obstruction.
Please post your model number for additional information.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 01-17-2009, 09:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Try running the machine in a timed dry mode.
If the timer now advances, it may be that half the heater coil is shot.
Some GE's use a dual coil depending on which side burns out, it can also stop the timer in Auto modes.
Here is an example of that type of dryer
http://www.applianceaid.com/image/geediagram.JPG
If you do not have the wiring diagram it may be glued to the back or they like to put them in the control console.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dryer timer wont work on automatic setting dirtracer9 Dryer Repair 2 11-26-2009 06:35 AM
Dryer wont heat up and timer cycles dont work. ggordon007 Dryer Repair 0 08-03-2009 06:47 AM
Whirlpool dryer no heat & timer wont shut off lsaustin Dryer Repair 1 06-20-2009 10:47 AM
Electric Dryer Wont Heat Clothes Carlos29 Dryer Repair 3 11-19-2008 02:56 PM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
