I just change the [FONT="Calibri","sans-serif"]hight-limit thermostat and the [FONT="Calibri","sans-serif"]heating element and Im still not getting the same hot temperature as before. Did I miss to change another part?[/FONT][/FONT]
The usual problem with heat is that something is blocking air passages, either inside the dryer, lint chute or outside in the vent from the dryer to the outside.
If these all check out, try replacing the operating thermostat.
