Discuss
Maytag LSE7806ACE
 in
Dryer Repair
washer fills when the dryer button s pished, but nothing else will work. I have replaced the washer timer, and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag LSE7806ACE
  #1 (permalink)
Old 04-20-2011, 11:08 AM
Junior Member
wixie4 is on a distinguished road
Question Maytag LSE7806ACE
Brand: Maytag   Age: 1 - 5 years
washer fills when the dryer button s pished, but nothing else will work. I have replaced the washer timer, and the dryer timer. I called Maytag, and the responce was " thats interesting, thats not supposed to happen."
Anyone have this happen?
  #2 (permalink)
Old 04-20-2011, 02:36 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Wixie,
I've seen similar problems like this(not exactly like this one). Usually, you'll find that there is a problem in the power supply to the laundry product. check and make sure your power cord and wiring at the terminal block on the back of the dryer are good and tight and there are no loose connections.
Do you have a multi meter, so you can check voltage at the outlet or terminal block when you start the machine ?
Improper voltage, under a load can cause all kinds of problems.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Stackable Dryer Buzzer sound, wont start LSE7806ace di011361 Dryer Repair 5 06-29-2014 10:37 AM
Maytag CA206 and Maytag CA207 wnlewis Washer Repair 0 08-31-2010 07:26 PM
Maytag LSE7806ACE Grinding Noise steveer Dryer Repair 8 12-15-2009 02:16 PM
