Discuss
Lubrication of Rollers and Idler Bearing
 in
Dryer Repair
I bought on your website all weareable parts to rebuild the dryer and I'm assembling it now. I want to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Lubrication of Rollers and Idler Bearing
  #1 (permalink)
Old 04-19-2011, 02:25 AM
Junior Member
razfly is on a distinguished road
Default Lubrication of Rollers and Idler Bearing
Model Number: MDG3050AGW   Brand: Maytag   Age: More than 10 years
I bought on your website all weareable parts to rebuild the dryer and I'm assembling it now. I want to know if lubrication is required for the new rollers and idler bearing. Serching in the web I found out contradicting instructions: lubricate with 3 in 1 oil, with lithium grease, don't lubricate at all because it will attract lint and damage the bearing, it is permanently lubricated at manufacture...
What's the right answer?
Razfly
Ads By Google
Related Models
International MDG3050AGW Dryer - Gas
Maytag MDG308DAWW Dryer - Gas
Maytag MDG30MC2A*
Maytag MDG30MC2AL Dryer - Gas
Maytag MDG30MC2AQ Dryer - Gas
Maytag MDG30MC2AW Dryer - Gas
Maytag MDG30MC2Ax Dryer - Gas
Maytag MDG30MC3A Dryer - Gas
Maytag MDG30MC3AL Dryer - Gas
Maytag MDG30MC3AW Dryer - Gas
Maytag MDG30MNAWW Dryer - Gas
Maytag MDG30MNVWQ Washer/dryer Laundry System
Maytag MDG30MNVWW Dryer - Gas
Maytag MDG30PC2A*
Maytag MDG30PC2AL Dryer - Gas
Maytag MDG30PC2AQ Dryer - Gas
Maytag MDG30PC2AW Dryer - Gas
Maytag MDG30PC2Ax Dryer - Gas
Maytag MDG30PC3AL Dryer - Gas
Maytag MDG30PC3AW Dryer - Gas
Maytag MDG30PCCWQ Dryer - Gas
Maytag MDG30PCCWW Dryer - Gas
Maytag MDG30PN3AL Dryer - Gas
Maytag MDG30PN3AW Dryer - Gas
Maytag MDG30PNHWQ Dryer - Gas
Maytag MDG30PNHWW Dryer - Gas
Maytag MDG30PNVWQ Dryer - Gas
Maytag MDG30PNVWW Dryer - Gas
Maytag MDG31PDAWS Dryer - Gas
Maytag MDG31PDAWW Dryer - Gas
Maytag MDG31PDSWS Dryer - Gas
Maytag MDG31PDSWW Dryer - Gas
Maytag MDG31PNAWW Dryer - Gas
Maytag MDG31PNSWW Dryer - Gas
Maytag MDG32PC2 Dryer - Gas
Maytag MDG32PC2AL Dryer - Gas
Maytag MDG32PC2AW Dryer - Gas
Maytag MDG32PC3AL Dryer - Gas
Maytag MDG32PC3AW Dryer - Gas
Frigidaire MDG336MBD0 Wwh(v10) / 27 " Gas Dryer
Frigidaire MDG336MBD1 Wwh(v1) / Gas Dryer
Frigidaire MDG336MBD2 Kel(v15) / Gas Dryer
Frigidaire MDG336MBW0 Tap(v11) / 27 " Gas Dryer
Frigidaire MDG336MBW1 Wwh(v2) / Gas Dryer
Frigidaire MDG336MBW2 Gib(v10) / Gas Dryer
Frigidaire MDG336MBWD0 Wwh(v10) / 27 " Gas Dryer
Frigidaire MDG336MBWL0 Frg(v4) / 27 " Gas Dryer
Frigidaire MDG336MBWW0 Gib(v15) / 27 " Gas Dryer
Frigidaire MDG336RBD0 Frg(v4) / 27 " Gas Dryer
Frigidaire MDG336RED0 Frg(v1) / Gas Dryer
Frigidaire MDG336RED1 Frg(v1) / Gas Dryer
Frigidaire MDG336RES0 Frg(v2) / Gas Dryer
Frigidaire MDG336RES1 Frg(v0) / Gas Dryer
Frigidaire MDG336RES2 Frg(v0) / Dryer
Frigidaire MDG336REW0 Frg(v3) / Gas Dryer
Frigidaire MDG336REW1 Frg(v2) / Gas Dryer
Maytag MDG3500BWQ Dryer - Gas
Maytag MDG3500BWW Dryer - Gas
Maytag MDG3600BWQ Dryer - Gas
Maytag MDG3600BWW Dryer - Gas
Maytag MDG3706AWW Dryer - Gas
Maytag MDG3757AWW Dryer - Gas
Maytag MDG3758AWW Dryer - Gas
Maytag MDG4000AWQ Dryer - Gas
Maytag MDG4000AWW Dryer - Gas
Maytag MDG4000AXQ Dryer - Gas
Maytag MDG4000AXW Dryer - Gas
Maytag MDG4000BWQ Dryer - Gas
Maytag MDG4000BWW Dryer - Gas
Maytag MDG4057BWB Dryer - Gas
Maytag MDG4057BWQ Dryer - Gas
Maytag MDG4057BWW Dryer - Gas
Frigidaire MDG436MBW0 Kel(v27) / 27 " Gas Dryer
Frigidaire MDG436RBD0 Frg(v2) / 27 " Gas Dryer
Frigidaire MDG436RBD1 Kel(v3) / Gas Dryer
Frigidaire MDG436RBD2 Gib(v11) / Gas Dryer
Frigidaire MDG436RBW0 Tap(v10) / 27 " Gas Dryer
Frigidaire MDG436RBW1 Kel(v4) / Gas Dryer
Frigidaire MDG436RBW2 Gib(v12) / Gas Dryer
Frigidaire MDG436RBWD0 Gib(v14) / 27 " Gas Dryer
Frigidaire MDG436RBWL0 Frg(v2) / 27 " Gas Dryer
Frigidaire MDG436RBWW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG436RED0 Frg(v1) / Gas Dryer
Frigidaire MDG436RED1 Frg(v1) / Gas Dryer
Frigidaire MDG436REW0 Frg(v2) / Gas Dryer
Frigidaire MDG436REW1 Frg(v2) / Gas Dryer
Maytag MDG4658AWW Dryer - Gas
Maytag MDG4806AWW Dryer - Gas
Maytag MDG4916AWA Dryer - Gas
Maytag MDG4916AWW Dryer - Gas
Maytag MDG5000BWQ Dryer - Gas
Maytag MDG5000BWW Dryer - Gas
Maytag MDG508DAWK Dryer - Gas
Maytag MDG508DAWW Dryer - Gas
Maytag MDG50MNAWW Dryer - Gas
Maytag MDG50MNVWQ Dryer - Gas
Maytag MDG50MNVWW Dryer - Gas
Maytag MDG50PN1AL Dryer - Gas
Maytag MDG50PN1AW Dryer - Gas
Maytag MDG50PN2VW Dryer - Gas
Maytag MDG50PNHWQ Dryer - Gas
Maytag MDG50PNHWW Dryer - Gas
Maytag MDG50PNTVQ Dryer - Gas
Maytag MDG50PNTVW Dryer - Gas
Maytag MDG50PNVWQ Dryer - Gas
Maytag MDG50PNVWW Dryer - Gas
Maytag MDG51PDAWW Dryer - Gas
Maytag MDG51PDSWW Dryer - Gas
Maytag MDG51PNAWW Dryer - Gas
Maytag MDG51PNSWW Dryer - Gas
Frigidaire MDG546RED0 Frg(v1) / Gas Dryer
Frigidaire MDG546RED1 Frg(v1) / Gas Dryer
Frigidaire MDG546RES0 Frg(v2) / Gas Dryer
Frigidaire MDG546RES1 Frg(v2) / Gas Dryer
Frigidaire MDG546RES2 Frg(v0) / Dryer
Frigidaire MDG546RET0 Frg(v3) / Gas Dryer
Frigidaire MDG546REW0 Frg(v4) / Gas Dryer
Frigidaire MDG546REW1 Frg(v3) / Gas Dryer
Maytag MDG5500AWQ Dryer - Gas
Maytag MDG5500AWW Dryer - Gas
  #2 (permalink)
Old 04-19-2011, 06:19 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
As you have found out different folks have different opinions.
Here is mine.
I would not use grease as it will just be pushed out of the bearing surfaces over time and become a lint collector.
The rear bearings are are usually oilite type so should not require lubrication.
Not sure about the idler wheel.
In any case I always put a drop or two of 3 in 1 or any good oil on the shafts when replacing these parts. As long as you do not go crazy with the oil it will not cause a problem and does help the parts wear in properly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Idler Pulley & Idler Bracket Lube ? mr.c40 Dryer Repair 1 04-07-2011 08:54 AM
How to install rollers.. flutientn27 Dryer Repair 1 11-12-2009 03:58 PM
maytag dryer - idler pulley/drum rollers lubrication patentable Dryer Repair 4 11-02-2009 02:52 PM
Roller Lubrication jealbers Dryer Repair 2 12-21-2008 03:43 AM
lubrication for dryer rebuilds videojc Dryer Repair 3 02-15-2008 11:34 AM
