Dry burner fires up and burns for 10 seconds then shuts down.
I reviewed a number of symtoms on-line and found that it was likely the valve coils. I purchased and replaced, but not change. Igniter works, gas fires up, then shuts down. If i let the dryer run, it attemps again but continues to shut down?
Any thoughts?
