Discuss
Dryer takes two cycles to dry
 in
Dryer Repair
I have a 110.96468800 Kenmore dryer. The problem I am having is that I have to run 2 cycles
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer takes two cycles to dry
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-30-2007, 09:01 AM
SlowGin SlowGin is offline
Junior Member
SlowGin is on a distinguished road
Default Dryer takes two cycles to dry
Model Number: 110.96468800   Brand: Kenmore   Age: More than 10 years
I have a 110.96468800 Kenmore dryer. The problem I am having is that I have to run 2 cycles to get the clothes dry. Here is what I have tried.
Checked the wall outlet it has 110 power at the required spots and 220 when I check the 2 110 together.
Cleaned the internal lint screen shoot, top to bottom, cleaned the blower fan at bottom of shoot, cleaned lint screen then ran water through it, it works fine.
Cleaned out the two sets of holes inside the drum, cleaned the exhaust shoot and the one on the house. It is the ridged 4" all the way through. This exhaust shoot in the house goes from the dryer straight up the wall and out the roof; this is about 16’ long and has no obstructions.
Started the dryer, it runs up to 170deg then immediately goes to 120deg then it continues this cycle over and over.
Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-06-2007, 11:55 AM
Junior Member
Default
I pulled the dryer away from the wall and ran a load and it finished drying in 1 cycle. I plugged it back into the wall and ran a load and it again took 2 cycles. I checked the 4” pipe all the way up the wall. It runs 16’ high and out the roof, this pipe is clean all the way through. There is no screen at the top just a cap to stop rain from getting in. And the pipe that connects the dryer to the wall is also clean and is rigid 4” tubing. Not sure what the problem is, almost like the fan cant push the air up 16’?
  #3 (permalink)
Old 11-08-2007, 03:41 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default scratch my head
I would scratch my head with this one too, as long as I was positive the vent tube riser was clear of lint... Then I would locate one of those rebuild kits for kenmore dryers made by whirlpool... Call APPros to see what the part number is for a kit, should be cheaper than buying the individual parts... There's 2 different kits, 1 for standard dryers and another for commercial heavy duty dryers... Comes with new belt, rollers, pulley, and most importantly new drum felt seals which may be the culprit in your situation... When these seals wear out they allow heated air to escape around the drum instead of flowing properly thru your clothes and out the exhaust vent... Taking too long to dry your clothes is a classic sympton of worn drum seals or clogged exhaust vent... cheers, kooler
__________________
  #4 (permalink)
Old 11-09-2007, 01:14 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
The dryer repair kit for this model includes a new belt, rollers, and idler pulley. Felt seals are separate though.
- Dryer repair kit (drive belt, 2 drum rollers, idler pulley, and instructions)
- Rear felt seal
- Front bearing and seal kit
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dryer not heating up on all cycles and not properly drying clothes. radioman464 Dryer Repair 1 10-18-2007 03:48 AM
Gas Dryer not drying during run cycles GMP Dryer Repair 1 09-28-2007 07:42 AM
Dryer Takes way to long to dry confused Dryer Repair 4 08-12-2007 08:38 PM
Takes too long to dry:Duet Scottpiggs Dryer Repair 4 08-10-2007 12:49 PM
Dryer Takes Very Long to Dry Clothes jdavis Dryer Repair 2 07-25-2007 04:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
