Discuss
Whirlpool Cabrio motor replacement
 in
Dryer Repair
hi there, the motor burned out on our whirlpool cabrio dryer wgd6600vw1, what would we need to replace this ourselves?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Cabrio motor replacement
  #1 (permalink)
Old 04-11-2011, 04:51 PM
Junior Member
stolarm is on a distinguished road
Default Whirlpool Cabrio motor replacement
Model Number: wgd6600vw1   Brand: Whirlpool   Age: 1 - 5 years
hi there, the motor burned out on our whirlpool cabrio dryer wgd6600vw1, what would we need to replace this ourselves? and how difficult is the replacement - is their a repair manual? Thank you! The dryer is less than a year and a half old!
Related Models
Whirlpool WGD6600VW1 29" GAS DRYER
Whirlpool WGD6600WL0 29"GAS DRYER
Whirlpool WGD7300XW0 27" ELECTRIC DRYER
Whirlpool WGD7400XW0 27" GAS DRYER
Whirlpool WGD7600XW0 27" GAS DRYER
Whirlpool WGD7800XB0 27" GAS DRYER
Whirlpool WGD7800XL0 27" GAS DRYER
Whirlpool WGD7800XW0 27" GAS DRYER
Whirlpool WGD7990XG0 DRYER
Whirlpool WGD8200YW0 DRYER
Whirlpool WGD8300SB0 27" GAS DRYER
Whirlpool WGD8300SB1 27" GAS DRYER
Whirlpool WGD8300SB2 27" GAS DRYER
Whirlpool WGD8300SE2 27" GAS DRYER
Whirlpool WGD8300SW0 27" GAS DRYER
Whirlpool WGD8300SW1 27" GAS DRYER
Whirlpool WGD8300SW2 27" GAS DRYER
Whirlpool WGD8410SW0 27"GAS DRYER
Whirlpool WGD8410SW1 27" GAS DRYER
Whirlpool WGD8500SR0 27"GAS DRYER
Whirlpool WGD8500SR1 27" GAS DRYER
Whirlpool WGD8600YW0 DRYER
Whirlpool WGD8800YC0 27" GAS DRYER
Whirlpool WGD8800YW0 27" GAS DRYER
Whirlpool WGD9050XW0 27" GAS DRYER
Whirlpool WGD9050XW1 GAS DRYER
Whirlpool WGD9150WW0 27" GAS DRYER
Whirlpool WGD9150WW1 27" GAS DRYER
Whirlpool WGD9151YW0 27" GAS DRYER
Whirlpool WGD9200SQ0 GAS DRYER
Whirlpool WGD9200SQ1 GAS DRYER
Whirlpool WGD9250WL0 27" GAS DRYER
Whirlpool WGD9250WR0 27" GAS DRYER
Whirlpool WGD9250WW0 27" GAS DRYER
Whirlpool WGD9270XL0 27"GAS DRYER
Whirlpool WGD9270XL1 27" GAS DRYER
Whirlpool WGD9270XR0 27"GAS DRYER
Whirlpool WGD9270XR1 27" GAS DRYER
Whirlpool WGD9270XW0 27"GAS DRYER
Whirlpool WGD9270XW1 27" GAS DRYER
Whirlpool WGD9300VU0 GAS DRYER
Whirlpool WGD9300VU1 GAS DRYER
Whirlpool WGD9371YL0 27" GAS DRYER
Whirlpool WGD9371YW0 27" GAS DRYER
Whirlpool WGD9400SB0 GAS DRYER
Whirlpool WGD9400SB1 GAS DRYER
Whirlpool WGD9400ST0 GAS DRYER
Whirlpool WGD9400ST1 GAS DRYER
Whirlpool WGD9400SU0 GAS DRYER
Whirlpool WGD9400SU1 GAS DRYER
Whirlpool WGD9400SW0 GAS DRYER
Whirlpool WGD9400SW1 GAS DRYER
Whirlpool WGD9400SW2 GAS DRYER
Whirlpool WGD9400SW3 GAS DRYER
Whirlpool WGD9400SZ0 GAS DRYER
Whirlpool WGD9400SZ1 GAS DRYER
Whirlpool WGD9400SZ2 GAS DRYER
Whirlpool WGD9400SZ3 GAS DRYER
Whirlpool WGD9400VE0 GAS DRYER
Whirlpool WGD9400VE1 GAS DRYER
Whirlpool WGD9450WL0 GAS DRYER
Whirlpool WGD9450WL1 GAS DRYER
Whirlpool WGD9450WL2 GAS DRYER
Whirlpool WGD9450WR0 GAS DRYER
Whirlpool WGD9450WR1 GAS DRYER
Whirlpool WGD9450WR2 GAS DRYER
Whirlpool WGD9450WW0 GAS DRYER
Whirlpool WGD9450WW1 GAS DRYER
Whirlpool WGD9450WW2 GAS DRYER
Whirlpool WGD9470WL1 GAS DRYER
Whirlpool WGD9470WL2 GAS DRYER
Whirlpool WGD9470WR1 GAS DRYER
Whirlpool WGD9470WR2 GAS DRYER
Whirlpool WGD9470WW1 GAS DRYER
Whirlpool WGD9470WW2 GAS DRYER
Whirlpool WGD94HEXL0 DRYER
Whirlpool WGD94HEXL1 27" GAS DRYER
Whirlpool WGD94HEXR0 DRYER
Whirlpool WGD94HEXR1 27" GAS DRYER
Whirlpool WGD94HEXW0 DRYER
Whirlpool WGD94HEXW1 27" GAS DRYER
Whirlpool WGD9500TC0 GAS DRYER
Whirlpool WGD9500TC1 GAS DRYER
Whirlpool WGD9500TC2 GAS DRYER
Whirlpool WGD9500TU0 GAS DRYER
Whirlpool WGD9500TU1 GAS DRYER
Whirlpool WGD9500TW0 GAS DRYER
Whirlpool WGD9500TW1 GAS DRYER
Whirlpool WGD9500TW2 GAS DRYER
Whirlpool WGD9500TW3 GAS DRYER
Whirlpool WGD9500TW4 GAS DRYER
Whirlpool WGD9550WL0 GAS DRYER
Whirlpool WGD9550WL1 GAS DRYER
Whirlpool WGD9550WL2 GAS DRYER
Whirlpool WGD9550WR0 GAS DRYER
Whirlpool WGD9550WR1 GAS DRYER
Whirlpool WGD9550WR2 GAS DRYER
Whirlpool WGD9550WW0 GAS DRYER
Whirlpool WGD9550WW1 GAS DRYER
Whirlpool WGD9550WW2 GAS DRYER
Whirlpool WGD95HEXL0 DRYER
Whirlpool WGD95HEXL1 27" GAS DRYER
Whirlpool WGD95HEXR0 DRYER
Whirlpool WGD95HEXR1 27" GAS DRYER
Whirlpool WGD95HEXW0 DRYER
Whirlpool WGD95HEXW1 27" GAS DRYER
Whirlpool WGD9600SU0 GAS DRYER
Whirlpool WGD9600TA0 27" GAS DRYER
Whirlpool WGD9600TA1 27" GAS DRYER
Whirlpool WGD9600TA2 27" GAS DRYER
Whirlpool WGD9600TB0 27" GAS DRYER
Whirlpool WGD9600TB1 27" GAS DRYER
Whirlpool WGD9600TU0 27" GAS DRYER
Whirlpool WGD9600TU1 27" GAS DRYER
Whirlpool WGD9600TW0 27" GAS DRYER
Whirlpool WGD9600TW1 27" GAS DRYER
Whirlpool WGD9600TW2 27" GAS DRYER
Whirlpool WGD9600TZ0 27" GAS DRYER
Whirlpool WGD9610XW0 27" GAS DRYER
Whirlpool WGD9750WL0 27" GAS DRYER
  #2 (permalink)
Old 04-12-2011, 09:51 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Stolarm,
There's a lot to do to access the motor, but it's relatively easy and can be done with basic hand tools.
1. Unplug dryer or disconnect power.
2. Turn off gas supply to dryer.
3. Raise the lint screen lid and remove the two screws from the top of the lint screen air duct.
4. Partially open the dryer door.
5. To remove the cabinet front:
a) While lifting the front corners of the cabinet top, (see the top right photo),press a putty knife against the left and right top locks and release them from the top. Rotate the cabinet top up and rest it against a wall.
b) Disconnect the door switch connector from the harness connector.
c) Remove the two 5/16˝ hex-head screws from the cabinet front.
d) Lift the front panel of the cabinet, unhook it from the bottom hangers.WARNING
3. Remove the cabinet front from the dryer
4. Reach under the drum to the drive motor and push the idler wheel arm to relieve the spring tension on the belt, then slide the belt off the idler and motor pulleys.
5. Loosen the two top and remove the two bottom 5/16
˝ hex-head screws from the front bulkhead.
6. Lift and unhook the two top bulkhead keyhole slots from the screws, and remove the bulkhead from the dryer.
7.
To remove the belt and drum:
a) Slide the belt off the back of the drum and remove it.
b) Pull the drum out the front of the cabinet and remove it.
***REASSEMBLY NOTE:
When you reinstall
the drum and belt, make sure that the hole in
the drum is toward the rear of the unit, (see
the above photo), and that both the front and
rear drum felt seals are flared out and not
folded under the edges of the drum.
5.
To remove the drive motor
a) Place a 13/16
˝ open end wrench on the back of the blower wheel, and a
7/16˝ open end or adjustable wrench on the front of the drive motor shaft
(flatted). Turn the drive motor shaft to the right (clockwise) and loosen the
blower wheel (left-hand thread).
b) Lift the top tab, and disconnect the wire harness connector from the drive motor.
c) Remove the front and rear clamps from the drive motor and its mounting bracket. To remove a clamp, press down on one end, and unhook it from the bracket tab.
You'll do fine,
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool duet dryer - motor/switch replacement thanks4help Dryer Repair 5 11-14-2017 06:22 PM
Humming Whirlpool - what motor & pump replacement parts do I need & HOW do I do it ? dishwasher hums Dishwasher Repair 1 12-31-2010 10:27 AM
Whirlpool dishwasher motor pump replacement suzieQ5 Dishwasher Repair 1 08-01-2010 12:30 AM
Whirlpool motor replacement question jstrange123 Dishwasher Repair 0 03-09-2010 06:59 PM
Kenmore/Whirlpool Dishwasher Pump Motor Assebly Replacement tegold Dishwasher Repair 3 08-18-2009 12:12 PM
