Discuss
Whirlpool Dryer will not run
 in
Dryer Repair
My dryer ran fine Thurs night, come Sun evening it would not start. I have tested all the thermostats and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer will not run
  #1 (permalink)
Old 01-12-2009, 09:51 PM
rose3694 rose3694 is offline
Junior Member
rose3694 is on a distinguished road
Default Whirlpool Dryer will not run
Model Number: LER4634EQ0   Brand: Whirlpool   Age: 5 - 10 years
My dryer ran fine Thurs night, come Sun evening it would not start. I have tested all the thermostats and thermal fuses with a continuity tester and they all show a completed circuit. I also checked my door switch and my push to start button and they are making a closed circuit when pushed. I followed the diagram on the schematics for the dryer that I found in the back for the timer and checked all the settings that should read closed and they are showed ok also. I also checked the outlet in the wall and it is showing electricity for both sides of the outlet. I even went to the extent of making sure each of the poles of the plug wire was making a connection to the terminal block.
I know using a continuity tester isn't exactly the way to go but I'm seriously limited on money and thats all I have to work with.
I'm also showing a circuit being completed through my heating element but it seems a bit weaker since the last time I had to work in the back of this dryer. I however can not find any broken spots in the element.
I'm currently at a loss as to how exactly to get my drum out of the way to make sure the motor is getting a connection. I've managed to get the front off and am supporting the drum currently till I can figure out how to get it out of the way.
Any suggestions would be welcome as I'm desperate to get this fixed as I have to do my husbands and my kids uniforms nightly and right now am having to hang clothes all over the house sigh.
Related Models
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
  #2 (permalink)
Old 01-13-2009, 11:01 AM
denman denman is online now
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is your parts breakdown
Model LER4634EQ0
Here is your wiring diagram
https://www.servicematters.com/docs/...%203401728.pdf
When you say that both sides of the line have power i assume you mean L1 to Neutral and L2 to Neutral.
When you checked your fuse and switches did you remove the wires from at least one side of the part you were measuring. This prevents reading an alternate/parallel circuit path.
The thermostats in the heater circuit have nothing to do with getting the motor started.
Your circuit path for starting the motor is
Neutral , DOOR switch , START SWitch, 5M contact on motor's centrifugal switch , motor's MAIN and START windings , THERMAL FUSE , BU/BK timer contacts , L1
Once the motor starts, the centrifugal switch is activated. This disconnects the START winding and switches in the heater.
The thermal fuse is on the blower, #23 in Section 3.
You could short the two wires for the fuse together, tape them up so they cannot short to the frame and give it a try. If it is blown do not run the unit like this as it is a safety device. Replace it ASAP.
__________________
  #3 (permalink)
Old 01-13-2009, 11:30 AM
Junior Member
Default
On section 1 item #9 should that be showing closed? because I pulled the wires off that and it was open.
As for checking the timer with wires off no so I will do that tonight when I get home.
And as for that thermal fuse um yeah that has been bypassed already :| the place didn't have it in stock the last time I worked on the dryer. I guess since I have it all open again I'll get now.
Thanks for the response. I'll post back when I know more. And thanks for those drawings those should be a bit helpful.
  #4 (permalink)
Old 01-13-2009, 12:46 PM
Senior Expert
APP Volunteer
Default
No
It should be approximately 4500 ohms.
It has no effect on getting the motor to start and is only used in Auto cycles.
In timed dry it is not in the circuit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer produce1549 Dryer Repair 1 11-12-2008 11:17 AM
Whirlpool Dryer tommett Dryer Repair 1 09-29-2008 07:36 AM
whirlpool dryer mike@buster4 Dryer Repair 0 12-02-2007 12:05 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 12:46 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
