Discuss
dave baker
 in
Dryer Repair
I purchased a new timer switch from appliancepartspros.com and the posts for the wires have one difference. the model#
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dave baker
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-29-2007, 04:21 PM
dbaker04 dbaker04 is offline
Junior Member
dbaker04 is on a distinguished road
Default dave baker
Model Number: ler6848awo   Brand: Whirlpool   Age: More than 10 years
the model# on the switch itself is identical on the old one and the new one but the posts are different.
the new one is one post less than the old one and there is a jumper wire on the old one to the post that is missing on the new one.
1=post and _ = post
old switch has on bottom posts:
GY 1_ T 1_1 W _1
JUMPER WIRE GOES FROM
GY 1 to T1
new switch has wire posts:
T 1_ _1 W _1
therefore no GY on new switch at all and no center T1 like old switch to hook jumper wire to.
T1_ on new is same as GY1_ on old
W _1 on both is the same
T 1_1 on old is where the difference is
can this switch still be used and if so what do i do with the jumper wire?
all the posts are the same as the center T1 regardless of GY/T/W labels on switch
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-29-2007, 05:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Dave
What are the part numbers of the old and the new timers?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 10-30-2007, 04:07 PM
Junior Member
Default
gene, the model # is M460-G
the only other number on the switchs are
new switch 3397273B
old switch 3397273
  #4 (permalink)
Old 11-01-2007, 03:21 AM
Junior Member
Default to gene
Gene, did you have any further info on this
thanks
dave
  #5 (permalink)
Old 11-01-2007, 03:44 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
A different site shows a timer part # 3397273 with no "B". Send the timer back, they shipped the wrong one.
__________________
  #6 (permalink)
Old 11-05-2007, 10:06 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Actually 3397273B is the same as 3397273. Whirlpool sometimes adds a letter to the end of a part number, but this does not make the part any different. So 3397273=3397273B as per Whirlpool, in fact the box itself should just say 3397273, even though the timer label will have the letter B on the end.
Dbaker, don't re-use the jumper wire. Connect all other wires as is on the old timer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dave P. Batman Dave Heating, Ventilation, and Air Conditioning (HVAC) 1 09-14-2007 10:57 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
