Discuss
short in wire
 in
Dryer Repair
My dryer was not heating. After testing and replacing most of the electrical parts. I found a short. It was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » short in wire
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-29-2007, 01:00 PM
dwstevens dwstevens is offline
Junior Member
dwstevens is on a distinguished road
Default short in wire
Model Number: LEA50AW   Brand: Amana   Age: 5 - 10 years
My dryer was not heating. After testing and replacing most of the electrical parts. I found a short. It was a orange wire running from the fabric selector switch to the timer. It was burnt at the timer. I spliced the wire and reconnected it. How ever, it only gets hot on time dry. It does not heat on auto dry. Do I need to replace the timer? or is there some thing else I can do?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-29-2007, 03:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before replace any parts I would recommend to run a few tests as described in the repair manual.
- Here are the break down diagrams for the Amana dryer Model LEA50AW
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 02:48 AM
kitchenaid cooptop short rena Oven Repair (including Ranges and Cooktops) 0 09-26-2007 01:24 PM
burnt out wire? lisaosborne Dryer Repair 1 09-19-2007 06:34 PM
Moisture Sensor wire dwiley824 Dryer Repair 1 09-09-2007 08:21 PM
stove causing short bevi Oven Repair (including Ranges and Cooktops) 7 08-11-2007 10:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
