| » How to remove control panel on GEW9868K dryer |
Model Number: 3978826 Brand: Whirlpool Age: 1 - 5 years
How do I remove control panel from top of dryer.
All (90%+) selection lights light up on front panel but am unable to select/ push start. I select the function and push start... nothing. About 12 months ago, a couple of the pre-programmed functions stopped recognizing my selection, they would not light up. I resorted to using the timer and heat selection manually. This past weekend, I couldn't get any lights, unplugged, plugged back in and lights lit, but start icon would not accept selection. Wondering if control panel has failed or relay(s)/ solenoid has gone bad on curcuit board. Your help would be appreciated before I order a new control panel that may or maynot solve problem. Local repair cannot/ does not wisht to be bothered. Thank you Related Models |
Hi Speadracer
The model number you posted is incomplete. In order to provide the most accurate advise I need you to post the complete model number of your dryer. Gene.
__________________
Professional appliance repair in Orange County, California. |
Most likely the problem with your dryer is a bad key panel. Replacing the console should solve the problem.
In the model number you provided still missing one letter and one number after "K". Gene.
__________________
do you have available instructions how to remove the console/ control panel from the dryer?!?
as for missing # and letter... not sure what I am missing, checked and rechecked missing #. as for the letter, my model is pewter (KL) all I know is... Whirlpool Dryer GEW9868KL, console #3978826 or AP3083190 thank you for your quick replies, so-that I can order hopefully the correct part and be back up and running by upcoming weekend. |
| Display Modes | |
| Do I have a bad control panel? | wenoch01 | Oven Repair (including Ranges and Cooktops) | 4 | 11-05-2007 05:51 PM |
| Control Panel lockout | Washman | Dishwasher Repair | 8 | 10-08-2007 10:00 PM |
| Dryer Control Panel Dead! | Corel | Dryer Repair | 1 | 08-10-2007 09:47 PM |
| can't remove back panel | ljticeman | Dryer Repair | 2 | 07-30-2007 06:36 PM |
| Replacing Control Panel | bhandg | Oven Repair (including Ranges and Cooktops) | 2 | 07-23-2007 05:30 PM |
