Discuss
Dryer Help - Noises, Metals Shavings
 in
Dryer Repair
I got an e-mail from a tenant saying that the dryer was making loud grinding and scratching noise and after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Help - Noises, Metals Shavings
  #1 (permalink)
Old 01-12-2009, 07:59 AM
Junior Member
osuturfman is on a distinguished road
Default Dryer Help - Noises, Metals Shavings
Brand: Roper   Age: 5 - 10 years
I got an e-mail from a tenant saying that the dryer was making loud grinding and scratching noise and after it was shut off they found small metal shavings in the inside of the dryer. I'm not an expert but, does this sound plausible and if so what might be the cause? Any help would be greatly appreciated. Thanks!!
Ads By Google
  #2 (permalink)
Old 01-12-2009, 08:18 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Glide and bearing gone
Metal to metal contact with front panel. Glide and bearing gone. Drum eating into front panel. Not pretty. Some folks just put up with it till the dang thang quits. Shame. If it is that far gone you gonna need a new front panel.
  #3 (permalink)
Old 01-12-2009, 08:33 AM
Junior Member
Default
Ballpark, what does that cost with labor?
  #4 (permalink)
Old 01-12-2009, 08:43 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
One other thing to check is run your hand around the ends of the drum just in case something has gotten wedged in between the drum and the frame.
Bra wires are famous for this though usually they just make a racket.
More likely to be the front glides as JW said.
__________________
  #5 (permalink)
Old 01-12-2009, 06:02 PM
Junior Member
Default
Any idea on a cost for this repair?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hotpoint dryer randomly makes noises galleyhand Dryer Repair 2 02-09-2010 09:17 PM
Grinding noise/Metal shavings koinoi Dryer Repair 1 12-31-2009 04:18 PM
Whirlpool Dryer makes a lot of vibration noises billjoe Dryer Repair 2 12-22-2009 10:02 AM
Dryer noises LWS Dryer Repair 1 06-12-2009 08:44 AM
dryer starts then stops and makes noises karenmpls Dryer Repair 6 01-18-2009 02:52 PM
