Discuss
fixed the ignitor, but still no gas
 in
Dryer Repair
Dryer is Whirlpool Gas Ultimate Care II, Model # above. No heat, so I stripped the whole thing down. Electric motor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » fixed the ignitor, but still no gas
  #1 (permalink)
Old 01-12-2009, 01:29 AM
supertramp supertramp is offline
Junior Member
supertramp is on a distinguished road
Default fixed the ignitor, but still no gas
Model Number: LGQ8858HQ   Brand: Whirlpool   Age: 5 - 10 years
No heat, so I stripped the whole thing down. Electric motor works fine, but no flame. The ignitor was not working and when I pulled it out it was broken, so I ordered a new one and replaced it. But now the new ignitor itself does not get any power (i.e. does not glow red).
I know that the ignitor is functional because when I apply voltage to it outside the dryer it turns red. And I've double-checked that all the wires are connected as they were (though the back covers of the dryer and the vent cover are still pulled off).
My question is - what should I do next? Why would the ignitor not be receiving power when the cycle is activated? I tried pulling out the heat sensor (my best guess!), but I don't know how to test it.
Thanks for your help.
PS - I bought a digital multimeter, but the truth is I don't really know what I'm doing with it! Instructions in this regard appreciated.
Related Models
Whirlpool LGQ8858HQ0
Whirlpool LGQ8858HQ1
Whirlpool LGQ8858HZ0
Whirlpool LGQ8858HZ1
Whirlpool LGQ8858JQ0
Whirlpool LGQ8858JQ2
Whirlpool LGQ8858JQ3
Whirlpool LGQ8858JT0
Whirlpool LGQ8858JT2
Whirlpool LGQ8858JT3
Whirlpool LGQ8858JZ0
Whirlpool LGQ8858JZ2
Whirlpool LGQ9030PQ0 29"gas Dryer
Whirlpool LGQ9030PQ1 29"gas Dryer
Whirlpool LGQ9508KQ0
Whirlpool LGQ9508KQ1
Whirlpool LGQ9508LG0
Whirlpool LGQ9508LW0
Whirlpool LGQ9508LW1 29"gas Dryer
Whirlpool LGQ9508PG0 29"gas Dryer
Whirlpool LGQ9508PG1 29"gas Dryer
Whirlpool LGQ9508PW0 29"gas Dryer
Whirlpool LGQ9508PW1 29"gas Dryer
Whirlpool LGQ9557KQ0
Whirlpool LGQ9557KQ1
Whirlpool LGQ9557KT0
Whirlpool LGQ9557KT1
Whirlpool LGQ9558KQ0
Whirlpool LGQ9558KQ1
Whirlpool LGQ9558KT0
Whirlpool LGQ9558KT1
Whirlpool LGQ9857LG0
Whirlpool LGQ9857LG1 29"gas Dryer
Whirlpool LGQ9857LW0
Whirlpool LGQ9857LW1 29"gas Dryer
Whirlpool LGQ9857PW0 29"gas Dryer
Whirlpool LGQ9858LG0
Whirlpool LGQ9858LG1 29"gas Dryer
Whirlpool LGQ9858LW0
Whirlpool LGQ9858LW1 29"gas Dryer
Whirlpool LGQ9858PG0 29"gas Dryer
Whirlpool LGQ9858PG1 29"gas Dryer
Whirlpool LGQ9858PW0 29"gas Dryer
Whirlpool LGQ9858PW1 29"gas Dryer
Whirlpool LGR2614BW0
Whirlpool LGR2614BW1
Whirlpool LGR2614BW2
Whirlpool LGR2614DW0
Whirlpool LGR2614DW1
Whirlpool LGR2614EW0
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB Range - S/c F/s Gas
Admiral LGR3330ADW Range - S/c F/s Gas
Admiral LGR3330ADZ Range - S/c F/s Gas
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0
Whirlpool LGR3424AW0
Whirlpool LGR3622BN0
Whirlpool LGR3622BW0
Whirlpool LGR3622DQ1
Whirlpool LGR3622DZ1
Whirlpool LGR3624BN2
Whirlpool LGR3624BW0
Whirlpool LGR3624BW1
Whirlpool LGR3624BW2
Whirlpool LGR3624DQ1
Whirlpool LGR3624EQ0
Whirlpool LGR3624EQ1
Whirlpool LGR3624EQ2
Whirlpool LGR3624JQ0
Whirlpool LGR3624JQ1
Whirlpool LGR3624JQ3 29" Gas Dryer
Whirlpool LGR3624PQ0 29" Gas Dryer
Whirlpool LGR3624PQ1 29" Gas Dryer
Whirlpool LGR3634EW0
Whirlpool LGR3634EW1
Whirlpool LGR3634EW2
Whirlpool LGR3634EW3
Whirlpool LGR3634JW0
Whirlpool LGR3634JW1
Whirlpool LGR3634JW2
Admiral LGR3725ADC Range - S/c F/s Gas
Whirlpool LGR4434AN0
Whirlpool LGR4434AN1
Whirlpool LGR4434AQ0
Whirlpool LGR4434AQ1
Whirlpool LGR4434AW0
Whirlpool LGR4434AW1
Whirlpool LGR4436AN0
Whirlpool LGR4436AW0
Whirlpool LGR4600PQ0 29" Gas Dryer
Whirlpool LGR4600PQ1 29" Gas Dryer
Whirlpool LGR4624BN0
Whirlpool LGR4624BN1
Whirlpool LGR4624BN2
Whirlpool LGR4624BQ0
Whirlpool LGR4624BQ1
Whirlpool LGR4624BQ2
Whirlpool LGR4624BW0
Whirlpool LGR4624BW1
Whirlpool LGR4624BW2
Whirlpool LGR4624DQ0
Whirlpool LGR4624DQ1
Whirlpool LGR4624DZ0
Whirlpool LGR4624DZ1
Whirlpool LGR4634BQ0
Whirlpool LGR4634BQ1
Whirlpool LGR4634BQ2
Whirlpool LGR4634DQ0
Whirlpool LGR4634DQ1
Whirlpool LGR4634DZ0
Whirlpool LGR4634EQ0
Whirlpool LGR4634EQ1
Whirlpool LGR4634EQ2
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
  #2 (permalink)
Old 01-12-2009, 06:34 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
You will have 1 of 2 problems. Take the back off the dryer, and in the middle close to the bottom will be the thermal fuse. It is white in color, and about an inch and a half long, by a 1/2 inch wide, and has 2 wires going to it. Take the 2 wires off, and ohm it out. If you get a reading, replace the flame sensor mounted on the side of the flame tube. If you don't get a reading, replace it, and that should do it. Let me know. Tom ApplianceEducator.com
  #3 (permalink)
Old 01-12-2009, 10:57 PM
Junior Member
Default
Hi Tom,
Thanks for your time and advice. Here's what I did: I disconnected the wires (but did not remove the fuse from the dryer) and used the digital multimeter on the two terminals. I cycled through each of the settings on the multiimiter, including -->|-, 200, 2K, 20K, 2M and 20M, and didn't get any signal in the digital display for any of them (i.e. it says 1___ and doesn't change).
When I apply the ohmeter to the flame sensor (removed from the dryer), on the 200 setting, I get a reading that maxes at around 8-10.
So does this mean there's no continuity in the fuse, and that the fuse is the culprit? Am I reading the multimeter correctly?
  #4 (permalink)
Old 01-13-2009, 09:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hopefully the article How to check continuity with Ohmmeter, posted on the forum earlier will help you.
Looks like the thermal fuse is bad.
Here are the break down diagrams for the Whirlpool dryer Model LGQ8858HQ0
__________________
  #5 (permalink)
Old 01-14-2009, 01:05 AM
Junior Member
Default all fixed
well it's all fixed. by way of closing this thread, the problem was with the thermal fuse. it was fairly easy to put back together, and all-in-all a simple job. total cost was $20 for the fuse and $40 for the ignitor, which i bought from this site and would highly recommend (had it in two days).
my theory (have no idea if it's correct) is that there was a short in the broken ignitor which blew the fuse.
thanks to all the experts on this site. I imagine it's a thankless task, but rest assured there are people out there like me who find your advice invaluable and appreciate your time very much.
  #6 (permalink)
Old 01-14-2009, 08:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I fixed my Bosch DW thanks to this forum! PaulW Dishwasher Repair 2 11-14-2008 12:34 PM
Well, I thought it was fixed, but... ssacrf Oven Repair (including Ranges and Cooktops) 3 06-30-2008 08:23 PM
I thought it was fixed, but....... Spug Washer Repair 7 04-26-2008 09:53 PM
Fixed leaky tub now clutch is clacking ???? jkl Washer Repair 5 03-16-2008 03:27 AM
