Discuss
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong
 in
Dryer Repair
I recently moved into a new house and my fiance change the plug on my dryer from a 4 prong
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong
  #1 (permalink)
Old 01-11-2009, 05:04 PM
Junior Member
Seeking Help is on a distinguished road
Default Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong
Brand: -brand-   Age: Less than 1 year
I recently moved into a new house and my fiance change the plug on my dryer from a 4 prong to a 3 prong. After that, the dryer seems to work, however it will not heat. Could he have made an error when switching the cord out, or is it more likely the heating element or thermostat???
  #2 (permalink)
Old 01-12-2009, 04:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A Model Number and Brand may help.
Check to make sure you have 240 volts at the receptacle.
Turn your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Depending which side goes out the unit will run but not heat.
Did he follow any directions re: the install sheet.
This probably would not cause your problem but make sure that a ground strap was added from the Neutral on the new cord to the machine's frame.
This is a safety issue.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire dryer 3-4 prong plug. No ground??? pirate Dryer Repair 9 02-10-2010 07:01 PM
installing a new 4 prong cord to 3 prong dryer nmcfay1226 Dryer Repair 9 02-09-2010 04:23 PM
Help changing a 3 prong to a 4 prong (dryer) plug Micheline Dryer Repair 4 11-28-2009 09:27 PM
Convert Kitchen Aid Dryer from 3 Prong Plug to 4 Prong Plug edd225 Dryer Repair 2 04-16-2009 07:59 PM
convert four prong plug to a three prong hooked25259 Dryer Repair 1 07-17-2008 09:11 PM
