173green
#1 Posted : Sunday, January 11, 2009 5:56:20 AM(UTC)
173green
I have a dryer that stop spining. The motor only hummed but don't spin. I changed the motor #279827 and it still only hums (with or without the belt attached). with it humming if I spin the blower wheel (without the belt) I can get the motor to start spin but once I stop it it will not restart without spining the blower wheel. I do notice that I don't need to push the start button it will start hummig once I turn the large knob. The motor had a sticker that said it thermostatly controlled is there something that reglates the amount of power to the motor? or any other suggest I could try?
Krysta
#2 Posted : Sunday, January 11, 2009 6:53:18 AM(UTC)
A Model Number might help so others can try and find a wiring diagram for this unit
173green
#3 Posted : Sunday, January 11, 2009 7:03:01 AM(UTC)
173green
gas dryer model LGR4634JQ2
#4 Posted : Sunday, January 11, 2009 8:00:57 AM(UTC)
Here is your parts breakdown
Model LGR4634JQ2
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528189.pdf
Only thing I can see that may cause this problem is it the Motors centrifugal switch has a problem.
On the wiring diagram it is shown in the motor off position.
So the current path when you push start is through the DOOR switch , START SWitch , centrifugal switch 5M to the motor's MAIN and START windings.
One the motor starts the centrifugal switch, switches out the START winding so the unit continues to run on just the MAIN winding.
Now if the switch is stuck in the run position or it is mis-wired the current path becomes DOOR switch , centrifugal switch 6M to the MAIN winding only. The motor then will just hum because it needs the extra power from the start winding to start rotating.
Usually thermostatically controlled just means that there is a thermal cutoff in the motor so that if it gets too hot the cutoff will open to prevent damaging the motor.
173green
#5 Posted : Sunday, January 11, 2009 2:25:27 PM(UTC)
173green
is the centrifugal switch on the motor? Is there a way to test it?
173green
#6 Posted : Monday, January 12, 2009 12:47:28 PM(UTC)
173green
With the start button disconected I have power to the motor when I turn the timer on. How do I test the timer? can I jump so wires?
173green
#7 Posted : Monday, January 12, 2009 4:25:10 PM(UTC)
173green
On the back of the timer which wires can I jump to test it?
#8 Posted : Monday, January 12, 2009 5:52:06 PM(UTC)
Yes
You could check it with an ohm meter. Remove the wires from the motor. Then check from 4M (should have had a blue wire going to it) to 6M (should have had a black wire going to it). It should be an open.
Not sure what you are trying to do?
173green
#9 Posted : Tuesday, January 13, 2009 2:43:26 AM(UTC)
173green
1. Trying to check timer to see if it has a (voltage drop) bad contact.
2. what would cause power to motor with start button disconected?
#10 Posted : Tuesday, January 13, 2009 5:27:20 AM(UTC)
I think that if you had a bad contact it would remove power to the motor.
I gave one possibility in my earlier post though that seems unlikely since both the original and replacement motors have the same symptoms.
Do you have a meter so you can measure the voltage to the motor.
It could be that one of the wires going to 5M on the centrifugal switch is shorting to ground/frame. You could check at the plug between Neutral and ground it should be a fairly high resistance.
Just thought of something. Disconnect the ground from the line cord where it comes into the machine. Should be a green wire that is connected to the frame, make sure it cannot touch the frame. Then plug the machine in if now the motor does not have power to it then a short to the frame is a high probability.
Do not touch the machine when plugged in, if for any reason the frame is live you could get a shock .
