trouts2
#1 Posted : Saturday, January 10, 2009 11:11:04 AM(UTC)
trouts2
The machine:
On the outside is 131066300
On the inside is 131284600B
A net posting I found said a 131066300 was a model FDG336LBS0.
The Frigidaire site would not recognize the above part numbers. I wrote to Frigidaire and they said there were no drawings or manuals available for my machine.
On the net I found the following drawings which seem to match my machine. The view of the top console has a start buttong and timer but the drawing does not show the heating level control dial but other than that the internals I think match mine.
FDG336LBS0
The problem is typical - it has electricity, gas, starts and runs ok with heat but after a while heat drops out.
I took the cover off and found no obstructions from dirt, dust or lint. The blower pipe was clear with a few pieces of dust or lint but very open.
The vent under the lint catcher is clear. It had quite a bit of lint on the sides which I cleaned up but there was plenty of room for air - unrestricted and capable of good flow.
The ductwork out from the dryer seems clear but I removed that so the back of the machine for the moment is not connected to the ductwork but dumps air into the cellar. Looking in there is clear. There was a little lint in there but I cleaned it up. It was only a small amount and the pipe very clear. I can see back along the length of the pipe and to the bend around to the blower. It's very open.
I took off the back cover and there was dust in there but no buildup.
I vaccumed the machine so there is no dust, dirt or lint anywhere. I tried the operation a few times and it's the same. It heats for a while then shuts off.
I have looked at a few sites that give some suggestions for going around with an ohm meter and getting some resistance and voltage readings. I don't think that will work because my machine seems to work like it should at first, at least for a few minutes. I think I'll get good readings.
EDIT UPDATE: I should add the thing for fine for years. The tenant had it free run one day for hours and it started behaving like this after that. It was a few days before I noticed it but may have started doing this right away. Although there's is a tenant I'm single and he is also. The machine has not gotten much use over the years.
What is the way to go from here?
Thanks,
David
misterfixall
#2 Posted : Saturday, January 10, 2009 7:39:57 PM(UTC)
misterfixall
try replacing valve coil kit on gas valve
trouts2
#3 Posted : Monday, January 12, 2009 3:07:56 AM(UTC)
trouts2
The gas dryer is actually a FDG546LBS1.
After a lot of net surfing the overall part for this problem seems to be the coils.
I think they are 5300622602 and 5308015680 which are available in kit
5303931775.
trouts2
#4 Posted : Monday, January 12, 2009 8:53:25 AM(UTC)
trouts2
Coil kit installed - two coils and the dryer is back working.
