| » Gas Dryer No heat |
Model Number: LDG8604AAE Brand: Maytag Age: More than 10 years
The Gas Dryer stop working last week: It started with heat for a minutes or so, the no heat at all for the rest of the time. The Dayer still turnning, but no heat.Please help me.
Quote:
Your post would lead me to suspect the gas valve coils, Part number: AP3094251 One of the ways to observe the gas valve operation on this unit, start the dryer and let it run approximately 10 minutes, you can then remove the 2 phillips head screws in the lower portion of the front panel, pull the bottom of the panel out a couple of inches, don't unhinge the top of the panel. When the thermostat cycles, you should hear a click, the glow bar igniter should start to glow, in a few seconds the glow should start to fade and the gas should be ignited and your flame appear. If there is no glow, suspect a weak,broken igniter, or inoperative flame sensor. If the glow appears but never fades, suspect a bad flame switch. If the glow appears and fades, but there is no flame ignition, suspect the gas valve coils. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Following your instruction, I have check the gas Dryer: 1. I hear a click, then 2. the glow appears and fades, then 3. I see flame for about 5-10 second 4. hear a click again, the flame stopped. The 1. 2. 3. 4 will repeat every couple of minutes. Please help me to check. Thanks, Al |
Quote:
Al, My mistake, I should have told you to check and clean the exhaust venting system, first(if you hadn't already). A restricted vent system will cause the hi limit switch to cycle open. My mistake, Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Joe / APP Team : 04-11-2011 at 06:13 AM. |
I sent the message too early. The problem has not been fixed: Since after removed the "high limit thermostat", the problem was gone. I thought that that part was the problem. But After replaced the parts and mounted it back. Problem still there. Could you tell me how to clean the "exhaust venting system"? Can I returned that "high limit thermostat"? Thanks, Allen |
Quote:
If it's too long to clean by hand, I use a small plumbers snake(25'longX1/4"shaft) with a rag attached to the end, slip the snake in the pipe from the vent hood, attach a shop towel to the end and turn the handle and pull the snake back out, carefully. There are other methods, some people use a leaf blower and there are vent cleaning companys, as well. Good Luck,
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
