| » Gas Dryer won't heat |
Model Number: MDG8400AWW Brand: Maytag Age: 1 - 5 years
When you turn the dryer on, the gas ignites for about 30 seconds and the goes off and will not ignite again.
I have already replaced the: Dryer Timer, Rotary Infinite Temp. switch, Moisture Sensor Thermostat, & Sensor. I still have the same problem. I have now ordered the Coil kit (2Coils for Gas Valve) and the Igniter Assembly. If these 2 additional parts do't solve my problem, what should I try next. John Bierke jbierke@roadrunner.com Ads By Google Related Models |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
