Discuss
Mystery dryer
 in
Dryer Repair
> We are having trouble with this gas dryer. On the regular dry cycle, the unit will run for about
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Mystery dryer
  #1 (permalink)
Old 04-04-2011, 08:07 AM
Junior Member
Jeep68 is on a distinguished road
Default Mystery dryer
Model Number: LCP664AWO   Brand: Whirlpool   Age: 5 - 10 years
> We are having trouble with this gas dryer. On the regular dry cycle, the unit will run for about 30 seconds then buzz and shut off regardless where on that cycle the pointer is set. On the delicate cycle, if the cycle is set at 70 or 80 minutes, the uhit will run until the pointer reaches about 40 minutes and then it will shut down.
I cannot find this dryer listed on the Whirlpool site or on your site. Is it that old? And, if it is, what else can I do to determine how to repair it?
Ads By Google
Related Models
Whirlpool LCR5232DQ0
Whirlpool LCR5232DQ1
Whirlpool LCR5232DQ2
Whirlpool LCR5232DQ3
Whirlpool LCR5232DQ4
Whirlpool LCR5232DQ5
Whirlpool LCR5232DZ0
Whirlpool LCR5232DZ1
Whirlpool LCR5232DZ2
Whirlpool LCR5232DZ3
Whirlpool LCR5232DZ4
Whirlpool LCR5232DZ5
Whirlpool LCR5232HQ0
Whirlpool LCR5232HQ1
Whirlpool LCR5232HQ2 Compact Automatic Washer
Whirlpool LCR5244AN0
Whirlpool LCR5244AN1
Whirlpool LCR5244AW0
Whirlpool LCR5244AW1
Whirlpool LCR7244DQ0
Whirlpool LCR7244DQ1
Whirlpool LCR7244DQ2
Whirlpool LCR7244DQ3
Whirlpool LCR7244DQ4
Whirlpool LCR7244DQ5
Whirlpool LCR7244DZ0
Whirlpool LCR7244DZ1
Whirlpool LCR7244DZ2
Whirlpool LCR7244DZ3
Whirlpool LCR7244DZ4
Whirlpool LCR7244DZ5
Whirlpool LCR7244HQ0
Whirlpool LCR7244HQ1
Whirlpool LCR7244HQ2 Compact Automatic Washer
Maytag LCRE200 Range - F/s Std Ele
Maytag LCRE300 Range - F/s Std Ele
Maytag LCRE305 Range - F/s Std Ele
Maytag LCRE350 Range - F/s Std Ele
Maytag LCRE355 Range - F/s Std Ele
Maytag LCRE383 Range - F/s Std Ele
Maytag LCRE400 Range - F/s Std Ele
Maytag LCRE600 Range - F/s Std Ele
Maytag LCRE650 Range - F/s Std Ele
Maytag LCRE655 Range - S/c F/s Ele
Maytag LCRE682 Range - S/c F/s Ele
Maytag LCRE683 Range - S/c F/s Ele
Maytag LCRE700 Range - S/c F/s Ele
Maytag LCRE750 Range - S/c F/s Ele
Maytag LCRE775 Range - S/c F/s Ele
Maytag LCRE800 Range - S/c F/s Ele
Maytag LCRE805 Range - S/c F/s Ele
Maytag LCRE883 Range - S/c F/s Ele
Maytag LCRG200 Range - F/s Std Gas
Maytag LCRG300 Range - F/s Std Gas
Maytag LCRG305 Range - F/s Std Gas
Maytag LCRG350 Range - F/s Std Gas
Maytag LCRG355 Range - F/s Std Gas
Maytag LCRG382 Range - F/s Std Gas
Maytag LCRG383 Range - F/s Std Gas
Maytag LCRG400 Range - F/s Std Gas
Maytag LCRG405 Range - F/s Cont Clean Gas
Maytag LCRG500 Range - F/s Std Gas
Maytag LCRG501 Range - F/s Std Gas
Maytag LCRG502 Range - F/s Std Gas
Maytag LCRG505 Range - F/s Std Gas
Maytag LCRG560 Range - F/s Std Gas
Maytag LCRG583 Range - F/s Cont Clean Gas
Maytag LCRG600 Range - F/s Std Gas
Maytag LCRG601 Range - F/s Std Gas
Maytag LCRG602 Range - F/s Cont Clean Gas
Maytag LCRG700 Range - S/c F/s Gas
Maytag LCRG705 Range - S/c F/s Gas
Maytag LCRG750 Range - S/c F/s Gas
Maytag LCRG755 Range - S/c F/s Gas
Maytag LCRG760 Range - S/c F/s Gas
Maytag LCRG760A Range - S/c F/s Gas
Maytag LCRG783 Range - S/c F/s Gas
Maytag LCRG800 Range - S/c F/s Gas
Maytag LCRG805 Range - S/c F/s Gas
Maytag LCRG860 Range - S/c F/s Gas
Maytag LCRG860A Range - S/c F/s Gas
Maytag LCRP200 Range - F/s Std Gas
Maytag LCRP205 Range - F/s Std Gas
Maytag LCRP300 Range - F/s Std Gas
Maytag LCRP382 Range - F/s Std Gas
Maytag LCSE400 Surface Unit - Ele
Maytag LCSE600 Surface Unit - Ele
Maytag LCSE601 Surface Unit - Ele
Maytag LCSG500 Surface Unit - Gas
Maytag LCSG501 Surface Unit - Gas
Maytag LCSG560 Surface Unit - Gas
Maytag LCSG600 Surface Unit - Gas
Amana LCU-514 Range - S/c S/i Ddraft Gas
Amana LCU-514D Range - S/c S/i Ddraft Gas
Amana LCU-514E Range - S/c S/i Ddraft Gas
Amana LCU-516D Range - S/c S/i Ddraft Gas
Amana LD10 Commercial Microwaves
Amana LD10D Commercial Microwaves
Amana LD10D2  Commercial Microwaves
Amana LD10MP  Commercial Microwaves
Amana LD10MPS  Commercial Microwaves
Amana LD510 Commercial Microwaves
Amana LD510D  Commercial Microwaves
Amana LD510M Commercial Microwaves
Amana LD510P  Commercial Microwaves
Amana LD510S Commercial Microwaves
Gaggenau LD816-610
Gaggenau LD816-620
Whirlpool LDA3000W0
Whirlpool LDA3000W1
Whirlpool LDA3000W2
Whirlpool LDA3000W3
Whirlpool LDA3005W0
Whirlpool LDA3005W1
Whirlpool LDA3005W2
Whirlpool LDA3005W3
Whirlpool LDA3800W0
Whirlpool LDA3805W0
Whirlpool LDA4000W0
Whirlpool LDA4000W1
  #2 (permalink)
Old 04-18-2011, 07:59 PM
Junior Member
Brian Scott is on a distinguished road
Default
Jeep,
From what you have said in your post it sounds like you have a bad timer. Timers are pretty expensive and depending on how old your dryer is you may be better off buying a new one. But this is what it sounds like to me. I have been doing dryer repairs for three years now and based on the info. given that is my guess.
Brian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mystery problem richappy Washer Repair 7 11-26-2010 03:00 PM
Dryer mystery jimmyds Dryer Repair 11 08-14-2010 10:03 AM
Kenmore Mystery Dryer Part onion99 Dryer Repair 2 04-19-2010 03:30 PM
Maytag Mystery Troubleshooter Dryer Repair 0 07-31-2009 07:27 PM
Mystery stain on surface of Kenmore dryer jimirod Dryer Repair 8 11-02-2008 05:55 PM
