ltroglin
#1 Posted : Friday, January 9, 2009 11:28:10 AM(UTC)
ltroglin
I live in an apartment and my dryer that is probably 6 months old is not drying efficiently. The landlord had someone come out and clean out the air vent from the outside, in. But it still does not heat up inside the dryer like it should. It took a load of towels 4 hours to dry. On the top of the dryer if you are facing it, you put your hand on the left hand upper corner and it is so hot you cannot touch it, but otherwise the rest is just a little warm. The back looks like metal or aluminum and that is extremely hot. So help if possible...
#2 Posted : Friday, January 9, 2009 3:45:56 PM(UTC)
Disconnect the unit from the vent system and run a load.
If worried about lint in the apartment;
take a pair of pantyhose, put one leg into the other and attach this to the dryer's exhaust. Leave enough room behind the dryer so it can blow out like a windsock.
Check the exhaust air volume and temperature.
If it dries in one run then you have a vent problem.
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
GE Dryer won't get hot on auto dry, but heats up on timed dry (Dryer Repair)
by kgleason 7/21/2020 6:19:46 AM(UTC)
GE dryer kicks immediately off when the start button is released (Dryer Repair)
by hollerg 6/3/2020 7:07:03 PM(UTC)
GE dryer runs but won't heat up (Dryer Repair)
by bristles 5/5/2020 5:44:54 PM(UTC)
