Note: if I don't click preview button before submit button I'm taken to registration page and lose everything in this box.
I have a Kenmore Elite 110.72932100 Gas Dryer of unknown age.
Symptoms: Blower wheel/fan is 'bouncing' or vibrating excessivly on motor shaft causing loud knocking sound.
Problem: Can not remove wheel/fan from motor shaft because it seems as if it has broken loose from the nut that remains tight on motor shaft. If prevent motor shaft from turning I can still turn the wheel.
Any suggestions on how to remove wheel short of cutting it off?
