whirlpool dryer wont always run?
power source is good, all sensors test out fine, start and run windings ohm out 0, door switch tests out with diagnostics on unit... dryer starts occasionally, but only runs for a short time and stops? sometimes starts on first try, sometimes upon trying several things (pushing door switch, rotating drum, switching selector) it will start. run times are inconsistent also sometimes stops immediately, sometimes runs several minutes. Any help would be appreciated.
| All times are GMT -7. The time now is 10:21 PM. |
