RobbieJo
#1 Posted : Sunday, April 3, 2011 5:50:35 AM(UTC)
RobbieJo
My dryer will start and run for about 15 min. It heats, it tumbles, but when I push the start button, I get a loud buzzing and it shuts off shortly after. Then about 30 min. it will start again.
Please help!
#2 Posted : Monday, April 4, 2011 3:17:55 AM(UTC)
I did not see this post so answered your other post about the start button first.
This is a different set of symptoms.
It sounds like the motor is overheating. It then trips it's internal thermal protect and you then have to wait for the motor to cool down before it will restart.
Can have a number of causes.
: Perhaps there is too much drag on the motor caused by a mechanical problem with the drum. Try turning the drum by hand in the correct direction, it should turn fairly easily. You may want to try this on a couple other dryers to get a feel for it.
: Perhaps the seal at the back of the blower is shot and it is blowing hot air back at the motor. Try running it with no heat if it now rums OK then this is a likely cause.
: The motor may be on it's last legs.
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
