Discuss
Dryer squealing and squeaking loudly
 in
Dryer Repair
My dryer has been making loud , high pitched squeaking, squealing sounds. Could you please tell me what the problem
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer squealing and squeaking loudly
  #1 (permalink)
Old 04-03-2011, 05:49 AM
Junior Member
upmawmaw is on a distinguished road
Default Dryer squealing and squeaking loudly
Model Number: 417.92702200   Brand: Kenmore   Age: 5 - 10 years
My dryer has been making loud , high pitched squeaking, squealing sounds. Could you please tell me what the problem is and what I need to do? Thank you so much.
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 04-04-2011, 04:37 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for KENMORE 41792702200 | AppliancePartsPros.com
A common cause on these units is the rear drum support bearing.
They dry out or wear and cause a squeal. Othe possible causes are the front supports, the idler wheel or the motor itself.
May even be something has fallen into the blower wheel.
In some cases something has jammed between the drum and the units frame, though usually this is a grinding noise.. Bra wires are famous for this.
hers is a manual which shoul help though I do not know if it is an exact match to your unit.
Frigidaire 27 inch Laundry Centers Gas and Electric (5995381885) Service Manual - ApplianceDigest.com
You will have to join the site but it is a great source of manuals and info for the appliance DIYer.
Try to find out the area thet the squeal is comming from to narrow it down. Often this is not possible because the dryer acts like one large speaker.
If it is the rear bearing. Clean it and check it for wear. Replace if necessary.
If it just needs re-lubing use a high temperature grease.
Also when taking it apart watch out for the grounding ball bearing at the back of the support bearing. Once released they like to take off and play hide and seek which can cost you a couple hours looking for it.
Here is a repair kit.
Part number: AP2142648
Click on the picture for more info.
__________________
  #3 (permalink)
Old 07-29-2012, 10:14 AM
Junior Member
Dozerdog1 is on a distinguished road
Default
I registered with this site because you implied that I could get a FREE service manual for my Kenmore Dryer. I cannot seem to simply get to it. Do you offer such a thing or not?
  #4 (permalink)
Old 07-29-2012, 03:52 PM
Senior Expert
APP Volunteer
Default
First I just volunteer some time at this site.
Second the link that I listed now charges for manuals and is not part of AppliancePartsPros.
Sorry but you are about 2 months too late.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Squeaking loudly tculler Dryer Repair 4 02-02-2013 06:45 AM
dryer squeals very loudly schrades Dryer Repair 1 11-14-2010 02:40 PM
dryer squeaks loudly bur831 Dryer Repair 1 11-08-2010 07:35 AM
Dryer Squeaks Loudly Tidalflats Dryer Repair 1 12-02-2009 04:42 AM
MY GE Dryer is squeeking very loudly Pompeo17 Dryer Repair 10 12-02-2008 04:05 PM
