| » Dryer Won't Heat |
Model Number: LER4634JQ1 Brand: Whirlpool Age: 5 - 10 years
Dryer runs, but will not heat.
What I have done:
Short of replacing the Timer...again...is there something I'm missing? Any assistance appreciated. Thanks!! Ads By Google Related Models |
You should be getting 240V at the element. Check your breakder and the plug.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
I have 240 at the wall outlet.
I have 240 at the power connection plate. Nothing wrong with the breaker, thank you. That was the very first thing I checked. I have a single breaker supplying 240 to the wall. I know I should be getting 240 at the element...that's why I ordered a new Timer Switch. If I am to believe the schematic (which by the way is the absolute WORST I have ever seen), ALL devices are controlled by the Timer Switch.I've now replaced the timer twice. No dice there either. I've received two defective timers...neither one reads the way it should according to the continuity chart at the top of the dryer schematic. And no two timers (3 total) read the same. None of the timers advance. Now the motor just hums, but doesn't start. I'm about ready to can it and buy an LG or Amana. |
Here is a wiring diagram, just to make sure we are on the same wavelength.
If you are getting 120 at the element and are in Auto cycle the timer will not advance. The timer motor is only getting less than 60 volts. The heater must be off re: one of the thermostats open so that the left hand side of the heater is at 240 volts (L2). Then the resistor will drop it down to 120 for the timer motor. Remove both wires from the heating element and check it for resistance. Then check each side to the case, sounds like you may have a grounded element.
__________________
- Last edited by denman : 01-10-2009 at 05:29 PM. |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
