| » Electric Dryer Will Not Run W/o Holding In Start Button |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.63952102 Brand: Kenmore Age: 1 - 5 years
My Kennmore Elite Dryer Will Only Run While You Hold In The Start Button. Let Go Of The Button And It Stops Immediately.
L.j.nigg |
Do not buy a new motor yet!!! If holding the start switch in, and the motor runs fine without drawing excessive current ( like over 8 amps) you have a good motor. If the motor start switch fails to switch to the run winding, you would hear a louder than normal motor hum!! Then smoke!!
__________________
You do have a relay in the console. I would check that 1st. Most whirlpool(kenmore) motors are pretty good. The relay # is AP3037419..wrench
if u can't answer here my email is joets135@hotmail.com thanks again and happy holidays
Hi niggdj
Most likely the problem with you dryer is a bad control board. Normally it should sense the start of the motor and it does not. I've seen it many times before. - The part number for the control board is AP4319168 Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Hum when start button is pushed | LOST | Dryer Repair | 1 | 10-01-2007 03:59 PM |
| Dryer will not start | bob38 | Dryer Repair | 2 | 09-19-2007 07:59 PM |
| Dryer start button | Yorba | Dryer Repair | 1 | 08-13-2007 05:13 PM |
| Dryer stops running after letting off the Start button | Andy | Dryer Repair | 10 | 08-01-2007 09:56 PM |
| Electric Dryer too hot | jim k | Dryer Repair | 3 | 07-25-2007 04:43 PM |
