| » Electric Dryer Will Not Run W/o Holding In Start Button |
I had the same problem with my dryer. Checked all the diagnostics that came with the dryer and everything was O'K. Replaced the circuit board and the dryer still would not run without holding the button in. Just for the heck of it switched the motor relay with the heat relay and the dryer ran without holding the button in. The continuity test showed the relay to be in working order and it wasn't. {text removed by admin, reason: site policy} Hope this helps you out. Karen
| Display Modes | |
| Hum when start button is pushed | LOST | Dryer Repair | 1 | 10-01-2007 04:59 PM |
| Dryer will not start | bob38 | Dryer Repair | 2 | 09-19-2007 08:59 PM |
| Dryer start button | Yorba | Dryer Repair | 1 | 08-13-2007 06:13 PM |
| Dryer stops running after letting off the Start button | Andy | Dryer Repair | 10 | 08-01-2007 10:56 PM |
| Electric Dryer too hot | jim k | Dryer Repair | 3 | 07-25-2007 05:43 PM |
