| » Sears Gas Dryer Intermittent heat |
Model Number: 417.92052101 Brand: Sears Age: 5 - 10 years
Sears Gas Dryer 417.92052101. When I first turn it on, it heats, but seems like it stops heating within 5 minutes. Drum still tumbles. Only way to get it to heat again is to open door and leave open for a few minutes, then close door and turn back on. Same problem, it will heat for roughly 5 minutes or so.
I've cleaned all the lint and dust, and made sure exhaust line isn't plugged. I have not run any continuity tests. It appears something is telling the gas to turn off for whatever reason. I did not peep into the unit to see if I have an orange glow. I either don't have a peep hole, or can't find it. Your help is much appreciated. thank you, Paul Ads By Google Related Models |
Paul,
Sounds like the problem with your dryer is a bad gas valve coils. This is very common situation. - The coil kit Part number: AP2150379 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Gas Dryer Intermittent Heat | volvomann | Dryer Repair | 0 | 10-11-2010 07:02 PM |
| gas dryer intermittent heat | rpuglia | Dryer Repair | 3 | 09-30-2009 01:33 PM |
| Dryer intermittent to no heat | edm812 | Dryer Repair | 6 | 07-30-2009 07:03 PM |
| Intermittent dryer heat | edm812 | Dryer Repair | 4 | 04-15-2009 06:08 AM |
| Gas Dryer intermittent heat, Gas smell | mikmica | Dryer Repair | 8 | 11-29-2007 05:32 PM |
