Discuss
Gas Dryer intermittent heat, Gas smell
 in
Dryer Repair
Dryer seems to heat ok at first but takes a long time to dry. The problem seems intermittent, and the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer intermittent heat, Gas smell
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-26-2007, 09:58 AM
mikmica mikmica is offline
Junior Member
mikmica is on a distinguished road
Default Gas Dryer intermittent heat, Gas smell
Model Number: LGR5620KQ1   Brand: Whirlpool   Age: 1 - 5 years
Dryer seems to heat ok at first but takes a long time to dry. The problem seems intermittent, and the auto time feature isnt working for the timer. I am going to check the manual timer after the post here. Twice we have checked the dryer while it was running and it was cold, and strong smell of natural gas in laundry area and drum. Vent seems fine, good flow outside.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 10:10 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi mikmica
Most likely the problem with your dryer is a bad coils (#13 & 14 on the burner break down diagram) on the gas valve.
- The part number for the new set of coils AP3094251
Coil kit for the gas valve
- Here are the break down diagrams for the Whirlpool dryer Model LGR5620KQ1
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 10-26-2007, 10:23 AM
Junior Member
Default
I did a little more checking, looking through the hole in the front to watch the burner action during cycle. Seems it lights and runs fine but as soon as it reaches its high temp and shuts off the burner, it doesnt re-light. I see the glow ciol glowing every minute trying to light but goes back out after 10 seconds or so with failed ignition of the burner. Could that still be the coils?
  #4 (permalink)
Old 10-26-2007, 10:26 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
No doubt this is a problem.
__________________
  #5 (permalink)
Old 10-26-2007, 10:29 AM
Junior Member
Default
Thanks Gene, I am going to order the coils right away.
  #6 (permalink)
Old 10-26-2007, 10:35 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #7 (permalink)
Old 10-26-2007, 02:11 PM
Junior Member
Default
Will do, parts on order.
  #8 (permalink)
Old 10-26-2007, 02:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #9 (permalink)
Old 11-29-2007, 05:32 PM
Junior Member
Default
the coils solved the problem, dries better than new, think it was defect from factory all along.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor intermittent spis Washer Repair 8 10-28-2007 03:49 PM
Oven Will not heat, no smell of gas bobafett2805 Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:11 AM
freezer/refrigeratornot cooling, motor running with clicking sound intermittent counterbob20 Refrigerator & Freezer Repair 2 10-07-2007 12:23 PM
musty smell rbird528 Dryer Repair 1 10-06-2007 03:44 AM
intermittent Cooling GE bobp Refrigerator & Freezer Repair 0 08-14-2007 05:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
