Discuss
Dryer is blowing thermal fuses
 in
Dryer Repair
The dryer is blowing the thermal cut out fuse on the heating element cage. The first replacement lasted 20 loads
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer is blowing thermal fuses
  #1 (permalink)
Old 01-05-2009, 08:37 AM
Junior Member
65gt350 is on a distinguished road
Default Dryer is blowing thermal fuses
Model Number: LE6150XSW0   Brand: Whirlpool   Age: More than 10 years
The first replacement lasted 20 loads the second only 1.
After the last one blew I have removed the lint chute and pulled a couple of handfuls of lint from the blower wheel area with no noticeable increase in air flow. I have also bypassed the thermal fuse and get a reading of ~155 degrees from the exhaust of the dryer. The thermal fuse is open, and so is the heater thermostat (ring around operating thermostat?) but the high limit and operating thermostat have continuity. The heater element has resistance within spec and is not short to the case.
Is there a anyway to test the heater thermostat or operating thermostat.
Any ideas and thank you.
Rich
Ads By Google
Related Models
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
Whirlpool LE7680XSW1 Residential Dryer
Whirlpool LE7680XSW2 Residential Dryer
Whirlpool LE7685XPW0 Residential Dryer
Whirlpool LE7685XPW1 Residential Dryer
Whirlpool LE7700XWW0 Residential Dryer
Whirlpool LE7760XWW0 Residential Dryer
Whirlpool LE7800XKW0 Residential Dryer
Whirlpool LE7800XKW1 Residential Dryer
Whirlpool LE7800XMW0 Residential Dryer
Whirlpool LE7800XMW1 Residential Dryer
Whirlpool LE7800XMW2 Residential Dryer
Whirlpool LE7800XPW0 Residential Dryer
Whirlpool LE7800XSN2 ELECTRIC DRYER
Whirlpool LE7800XSW0 Residential Dryer
Whirlpool LE7800XSW1 Residential Dryer
Whirlpool LE7800XSW2 Residential Dryer
Whirlpool LE7800XSW3 Residential Dryer
Whirlpool LE7800XW2 ELECTRIC DRYER
Whirlpool LE7805XPW0 Residential Dryer
Whirlpool LE7810XPW0 Residential Dryer
Amana LE8107L2 WASHER-TOP LOADING
Amana LE8107W2 DRYER- ELE
Amana LE8207L2 WASHER-TOP LOADING
Amana LE8207L3 WASHER-TOP LOADING
Amana LE8207W2 DRYER- ELE
Amana LE8207W2B DRYER- ELE
Amana LE8207W3 DRYER- ELE
Amana LE8217L2 DRYER- ELE
Amana LE8217W2 DRYER- ELE
Amana LE8267L2 WASHER-TOP LOADING
Amana LE8267W2 DRYER- ELE
Amana LE8317L2 DRYER- ELE
Amana LE8317W2 DRYER- ELE
Amana LE8317W2B DRYER- ELE
Amana LE8327W DRYER- ELE
Amana LE8367L2 WASHER-TOP LOADING
Amana LE8367W2 DRYER- ELE
Amana LE8407L2 DRYER- ELE
Amana LE8407W DRYER- ELE
Amana LE8407W2 DRYER- ELE
Amana LE8457L2 DRYER- ELE
Amana LE8457W DRYER- ELE
Amana LE8457W2 DRYER- ELE
Amana LE8467L2 DRYER- ELE
Amana LE8467W2 DRYER- ELE
Amana LE8507W DRYER- ELE
Amana LE8517L2 DRYER- ELE
Amana LE8517W2 DRYER- ELE
Amana LE8517W2B DRYER- ELE
Amana LE8567L2 DRYER- ELE
Amana LE8567W2 DRYER- ELE
Whirlpool LE8600XWW0 Residential Dryer
Amana LE8607L2 DRYER- ELE
Amana LE8607W DRYER- ELE
Amana LE8607W2 DRYER- ELE
Whirlpool LE8650XWW0 Residential Dryer
Whirlpool LE8860XWQ0 Residential Dryer
Amana LE9002 WASHER-TOP LOADING
Amana LE9002 DRYER- ELE
Amana LE9012 WASHER-TOP LOADING
Whirlpool LE9100XTW0 Residential Dryer
Whirlpool LE9100XTW1 Residential Dryer
  #2 (permalink)
Old 01-06-2009, 02:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Make sure the vent outside the dryer is made according to the Installation instructions and is not obstructed.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-06-2009, 03:04 PM
Junior Member
Default
The vent is not obstructed. I have tested the operating Thermostat by using a hair dryer. It appears to open at 155 and close at 120. I have also bypassed the operating thermostat and was able to get the high limit thermostat to open so I know that it is functional too. I also pulled the element and it looks good (no breaks, no sag).
Is it possible that the blower is not drawing enough air through the drum and is there a test. The current exhaust feels pretty strong and the three flaps on the outside vent open up. I found a test for the exhaust. I took a 2"x2" piece of paper and placed it in the dryer. I let it run and when I opened the door the paper was on the vent.
Thank you
Rich
Last edited by 65gt350 : 01-06-2009 at 10:03 PM. Reason: Added exhaust test results
  #4 (permalink)
Old 01-07-2009, 07:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Possible there is more current drawn by the motor than it suppose to be. The thermal fuse is in the motor circuit. You have to have a special clamp on meter to measure it.
__________________
  #5 (permalink)
Old 01-08-2009, 04:11 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
I would run the unit in an air only cycle, if it blows the fuse then you know it is a motor problem.
Pulling a handful of lint out of the blower is perhaps a clue.
I would open it up and give it a good cleaning.
Also check that the blower wheel is tight on the motor shaft.
Could be that it is partially stripped so it grabs most of the time but every once in a while it lets go.
Also check the filter screen and the holes at the back of the drum.
Especially if you use liquid fabric softener. It can leave a coating and drastically reduce air flow.
__________________
  #6 (permalink)
Old 01-08-2009, 05:12 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Have you pulled the heating element to see if it was hitting the case, and causing the thermal fuse to blow? I did notice, you said you in your initial e-mail that said the resistance to element didn't show that it was ground to the case. I have been fooled before. Just wondering if you pulled it to eye ball it. Tom ********************************************
  #7 (permalink)
Old 01-08-2009, 09:18 AM
Junior Member
Default
I don't really want to put another fuse in until I know for sure what is causing the problem. I have pulled the element and it looks good. I also ran the machine with the element housing laying on the ground to see if it shorts when heated and it appeared good. I am thinking about putting a thermometer in where the thermal cutout fuse goes and trying to measure the temperature to see if clearing the lint was the problem. I don't think so since I can't tell any difference in air pressure coming out the vent.
Could it be a timer issue. I have been running a few loads through trying to figure it out and have noticed that the AUTO setting does not move that quickly. The timed mode works fine and I am running a Knits load now.
Thanks for your responses.
  #8 (permalink)
Old 01-08-2009, 04:54 PM
Senior Expert
APP Volunteer
Default
I really like denmans idea. Put another fuse in, and run the dryer with a no heat setting, and see if it blows. If it does it is the motor. Other then the element it is the highest drawing amperage in the unit. Tom ********************************************
  #9 (permalink)
Old 01-08-2009, 06:41 PM
Senior Expert
APP Volunteer
Default
Do not have the wiring for this unit but I doubt it is a timer problem.
It is normal for Auto to run slower than Timed Dry.
The timer only advances when the heating element is off in Auto.
__________________
  #10 (permalink)
Old 01-10-2009, 10:44 AM
Junior Member
Default
Denman,
Thanks for that bit of information. So if I understand this right when the dryer is in Timer mode the cycling thermostat or high limit thermostat is controlling the heat. In Auto the timer needs to get feedback from the cycling thermostat to advance? How does the timer get that information?
I am thinking of starting over with my diagnostic testing. Can you validate my logic?
1) Bypass TCO on heating element cage (already open)
2) Bypass Cycling thermostat to test high limit Stat on heating element cage ( I should see the heating element shut down in Auto mode once temp is high enough) If it does move to test cycling thermostat
3) Bypass High limit thermostat to test Cycling thermostat ( I should see the element turn off at a dryer vent temp of 160 degrees
If the all of the above tests good it means I am having problems getting the heat from the heater element to the dryer vent. Do you know what the temp in the drum should be? I figure I can through an instant read thermometer in the drum and get a reading that is close.
Thank you,
Rich
3)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermal fuses blowing Nathan Vereide Dishwasher Repair 0 11-18-2009 01:49 PM
whirlpool dryer going through thermal fuses knightmare Dryer Repair 3 10-24-2009 02:19 AM
Dryer thermal fuse keeps blowing pocketpet3500 Dryer Repair 3 08-19-2009 05:26 PM
Whirlpool Dryer - Eating Thermal Fuses minomine Dryer Repair 5 05-31-2009 05:40 AM
Whirlpool dryer-thermal fuse keeps blowing needs help Dryer Repair 4 04-13-2009 03:48 PM
